How to position and render a button outside the parent's limit?
The behavior of the flag LV_OBJ_FLAG_OVERFLOW_VISIBLE is not clear to me. I thought that when adding this flag to a button, it would be drawn even outside the limits of its parent.
Simulator with resolution of 800 x 480
9.1
I want to get something like this image:
I tried to add LV_OBJ_FLAG_OVERFLOW_VISIBLE to parent and to button. The only way I found to get the result is: Creating a third object with a transparent background and using it as the parent of the header and button. But I would like to save a few bytes of memory and do without this extra object.
[image]
void add_header(void)
    lv_obj_t *header = lv_obj_create(lv_screen_active());
    lv_obj_set_size(header, lv_pct(100), 50);
    lv_obj_set_pos(header, 0, 0);
    lv_obj_set_style_bg_color(header, lv_palette_main(LV_PALETTE_BLUE_GREY), 0);
    lv_obj_remove_flag(header, LV_OBJ_FLAG_SCROLLABLE);
    lv_obj_t *puller = lv_button_create(header);
    lv_obj_set_size(puller, lv_pct(25), 45);
    lv_obj_align(puller, LV_ALIGN_CENTER, 0, 20);
    lv_obj_add_flag(puller, LV_OBJ_FLAG_OVERFLOW_VISIBLE);
Result:
If the object is outside the screen area (lv_screen_active()), it cannot be displayed.
I understand your point but I think it’s not the case.
In the code I’ve shown, the object “header” is inside lv_screen_active area and the object “puller” is inside the “header” area.
From the documentation I had understood that the LV_OBJ_FLAG_OVERFLOW_VISIBLE flag would cause the button to be rendered beyond the limit of the parent (which is the header object in the example) and would then be rendered in lv_screen_active:
The flag is set to the parent.
    lv_obj_t* header = lv_obj_create(lv_screen_active());
    lv_obj_t* puller = lv_button_create(header);
    lv_obj_add_flag(header, LV_OBJ_FLAG_OVERFLOW_VISIBLE);
Thanks for the reply.
But I think I’ve found a bug then because on my setup this is the result:
@Stipa889 Which version of LVGL are you using?
I’m running the simulator on Ubuntu 22.04.
Tried with LVGL Tag v9.1.0 and from branch master/HEAD.
If I apply also for the puller and header the result is the same:
Does the pulldown thing need to be a child of the header? Otherwise you could always just make it a child of the active screen instead or a child of lv_layer_top().
Hello, thanks for your time.
Doesn’t exactly need it. But I chose this hierarchy to facilitate alignment and because I thought it would be a good practice
I chose to continue with the development and leave this button to be validated on the final hardware as soon as it arrives.
I solved it by creating an object with a transparent background and adding the two components as childs.
The result so far is like this:
drawer
I colored the parent object gray to identify it
I recognize this problem. Sometimes it gets rendered and sometimes not with the flag: LV_OBJ_FLAG_OVERFLOW_VISIBLE. It seems not reliable.
