esp32s3 esp-idf:v5.1.1 LVGL:v8.3.10
From lv_drivers migrate SHARP MIP driver to lvgl_esp32_drivers and display lvgl demo correctly
From lv_drivers migrate sharp_mip.c and sharp_mip.h to lvgl_esp32_drivers, modify the corresponding cmakelists.txt, lvgl_helper.c and other related files, set and select the corresponding hardware and spi pins, initialize in main, and modify the data sending function to the corresponding disp_spi The function in .c, after doing this, the screen did not respond.
and ```
tags:
