Porting LCD ST7586S(118X281) to LVGL7.11, I have an array[118X281] for screen pixels, a pixel each byte.
for now , I have LCD ST7586S work fine with LVGL7.11 by implementing flush function below,
lcd_fbx[118X281] = {0xAA,0xAA};//screen buffer, a pixel for each byte
void st7586s_flush(int32_t x1, int32_t y1, int32_t x2, int32_t y2, const lv_color_t * color_p)
/*Return if the area is out the screen*/
if(x2 < 0) return;
if(y2 < 0) return;
if(x1 > ST7565_HOR_RES - 1) return;
if(y1 > ST7565_VER_RES - 1) return;
int32_t act_x1 = x1 < 0 ? 0 : x1;
int32_t act_y1 = y1 < 0 ? 0 : y1;
int32_t act_x2 = x2 > ST7565_HOR_RES - 1 ? ST7565_HOR_RES - 1 : x2;
int32_t act_y2 = y2 > ST7565_VER_RES - 1 ? ST7565_VER_RES - 1 : y2;
int32_t x, y;
uint8_t row1 = y1;
uint8_t row2 = y2;
uint8_t *buf = (uint8_t*) color_p;
/*Refresh frame buffer*/
for(y = y1; y <= y2; y++) {
for(x = x1; x <= x2; x++) {
if(lv_color_to1(*color_p) != 0) {
lcd_fbx[281*y + x] = 1;
} else {
lcd_fbx[281*y + x] = 0;
color_p ++;
write_com(0x2A);// Column Address Setting
write_data(0x00);
write_data(0x00);
write_data(0x00);
write_data(0x5D);
write_com(0x2B);// Row Address Setting
write_data(0x00);
write_data(y1);
write_data(0x00);
write_data(y2);
write_com(0x2C); //Write Display DATA
uint8_t*xbuf = NULL;
uint8_t out[96] = {0x00};
for(uint8_t row = row1; row <= row2; row++)
memset(out,0,sizeof(out));
xbuf = &lcd_fbx[281*row];
write_281byte_281pixel_ST7586S(xbuf,out);
write_data_dma(out,94);
in this case, however, it is discovered that screen flushing slow when switching screens, so I want to use callback functions below,
disp_drv.set_px_cb = st7586s_set_px_cb
disp_drv.rounder_cb = st7586s_rounder_cb
code implementation is below,
void st7586s_set_px_cb(lv_disp_drv_t * disp_drv, uint8_t * buf, lv_coord_t buf_w, lv_coord_t x, lv_coord_t y, lv_color_t color, lv_opa_t opa)
/* Write to the buffer as required for the display.
* Write only 1-bit for monochrome displays mapped vertically:*/
buf += (281 * y + x);//as 281 pixel each row, and buf equals lcd_fbx defined below
if (color.full)
(*buf) =1;
(*buf) =0;
void st7586s_rounder_cb(struct _disp_drv_t * disp_drv, lv_area_t *area)
//area->y1;
//area->y2;
//for now do nothing
void lv_port_disp_init(void)
/* Example for 1) */
static lv_disp_buf_t disp_buf_1;
lv_disp_buf_init(&disp_buf_1, lcd_fbx, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX); /*Initialize the display buffer*/
* Register the display in LVGL
lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = 281;//128;
disp_drv.ver_res = 118;//64;
disp_drv.flush_cb = disp_flush;
disp_drv.set_px_cb = st7586s_set_px_cb;
disp_drv.rounder_cb = st7586s_rounder_cb;
/*Set a display buffer*/
disp_drv.buffer = &disp_buf_1;
however, when code running , the screen displayed but not as expected, I can see the labels with strings are not placed in the expected position(should be in the center of the LCD screen) and label’s background is broken displayed.
In function void st7586s_set_px_cb, set 1 or 0 in the right position in the buffer (lcd_fbx[118X281] , so only parameter x and y were made use of, but as a result, I didn’t get what I was expecting on the screen.
and it seems that I am using the parameters below the wrong way.
uint8_t * buf
lv_coord_t buf_w
lv_coord_t x
lv_coord_t y
could you please help me with this?
A full screen(118X281) buffer(lcd_fbx[118X281]) used.and it is a byte for a pixel on screen.
Implementing function void st7586s_set_px_cb for speeding up flush ( next step I want to squash buffer size.)
MIMXRT1051
LVGL V7.11
To make st7586s_set_px_cb() and st7586s_rounder_cb() work fine with LCD ST7586S just as expected
For a porting without st7586s_set_px_cb() and st7586s_rounder_cb() , LVGLV7.11 works fine with LCD ST7586S, because of performance I want to make use of st7586s_set_px_cb() and st7586s_rounder_cb() but not work yet.
The code block(s) below:
if(x2 < 0) return;
if(y2 < 0) return;
int32_t x, y;
uint8_t row1 = y1;
uint8_t row2 = y2;
} else {
color_p ++;
write_data(0x00);
write_data(0x00);
write_data(0x00);
write_data(0x5D);
write_data(0x00);
write_data(y1);
write_data(0x00);
write_data(y2);
if (color.full)
(*buf) =1;
(*buf) =0;
//area->y1;
//area->y2;
