Great library, thank you. I tried searching for an answer here but couldnt’ find one.
How do I pass just the full values from the lv_color_t * color_p buffer pointer that are passed to the flush function?
I want to pass all the RGB values to my SPI transfer function at once rather than use for loop through the width and height and send one pixel at a time.
I’ve seen functions on the forum that just pass the color_p into DMA, but how is the RGB bytes extracted if this is a struct (lv_color_t)?
NRF52840 with Nordic SDK v15.0
Pass just RGB bytes from LVGL buffer into SPI write function.
This is what I’ve tried (in theory)
Flush function
void st7789_flush(lv_disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p)
set_addr_window(area->x1, area->y1, area->x2, area->y2);
NRF_LOG_INFO("In display flush with area x1: %d, x2: %d, y1: %d, y2: %d", area->x1, area->x2, area->y1, area->y2);
spi_write(&color_p->full, sizeof(color_p));
lv_disp_flush_ready(disp); /* Indicate you are ready with the flushing*/
lv_color_t struct
typedef union {
struct {
#if LV_COLOR_16_SWAP == 0
uint16_t blue : 5;
uint16_t green : 6;
uint16_t red : 5;
#else
uint16_t green_h : 3;
uint16_t red : 5;
uint16_t blue : 5;
uint16_t green_l : 3;
} ch;
uint16_t full;
} lv_color16_t;
SPI write function
static inline void spi_write(const uint8_t * data, size_t size)
// APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, data, size, NULL, 0));
nrfx_err_t err_code;
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TX(data, size);
uint32_t flags = NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER;
err_code = nrfx_spim_xfer(&spi_st7735_instance, &xfer_desc, flags);
APP_ERROR_CHECK(err_code);
N/A
