I have a list in which I add some buttons using the lv_list_add_btn function. I can’t manage to navigate through it using a rotary encoder.
ESP32 with the latest ESP-IDF.
I’m using the master branch, latest commit as of now (343605eba).
A scrollable list of button which can be focused with an encoder.
I tried embedding the list in a group, associate the group with the encoder and set the group to edit mode, none worked.
This code can’t run in the simulator due to the encoder driver.
The encoder read function (prints the delta, so I assume it works):
bool hmi_encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data)
data->enc_diff = hmi_encoder_moves();
if (data->enc_diff != 0) {
ESP_LOGD(TAG, "Encoder delta: %d", data->enc_diff);
data->key = data->enc_diff < 0 ? LV_KEY_LEFT : LV_KEY_RIGHT;
// Encoder with no button
return false;
The menu:
tk_bottom_bar_configuration original_bottom_bar_configuration;
bool menu_open = false;
bool menu_flag = false;
lv_obj_t *menu;
lv_group_t *menu_group;
lv_obj_t *bottom_bar;
static void menu_event_cb(lv_obj_t *obj, lv_event_t event)
ESP_LOGD(TAG, "Menu group event callback");
if (event == LV_EVENT_KEY)
ESP_LOGD(TAG, "Menu group event callback received a key");
uint32_t *key = lv_event_get_data();
if (*key == LV_KEY_LEFT || *key == LV_KEY_UP || *key == LV_KEY_PREV)
ESP_LOGD(TAG, "Menu group event callback moving list up");
lv_list_up(menu);
else if (*key == LV_KEY_RIGHT || *key == LV_KEY_DOWN || *key == LV_KEY_NEXT)
ESP_LOGD(TAG, "Menu group event callback moving list down");
lv_list_down(menu);
void hide_menu(lv_obj_t *menu)
// Hide the menu
void show_menu(tk_bottom_bar_configuration current_bb_conf, bool left)
unsigned int items = left ? current_bb_conf.left_button.items_count : current_bb_conf.right_button.items_count;
tk_menu_item *menu_items = left ? current_bb_conf.left_button.menu : current_bb_conf.right_button.menu;
// Menu generation
// TODO: Automatic resize
menu = lv_list_create(lv_scr_act(), NULL);
menu_group = lv_group_create();
lv_group_add_obj(menu_group, menu);
lv_list_set_scrollbar_mode(menu, LV_SCROLLBAR_MODE_AUTO);
lv_list_set_anim_time(menu, 200);
lv_obj_set_width(menu, 140);
lv_obj_add_style(menu, LV_LIST_PART_BG, &tk_style_menu);
lv_obj_add_style(menu, LV_LIST_PART_SCROLLABLE, &tk_style_menu);
lv_obj_t *btn;
for (int i = 0; i < items; i++)
btn = lv_list_add_btn(menu, NULL, menu_items[i].text);
lv_obj_add_style(btn, LV_BTN_PART_MAIN, &tk_style_menu_button);
lv_obj_set_style_local_pad_ver(btn, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, 6);
// Event callback
lv_indev_set_group(encoder_indev, menu_group);
lv_group_set_editing(menu_group, true);
lv_group_focus_obj(menu);
lv_obj_set_event_cb(menu, menu_event_cb);
// Update height
// Update variables
// Update bar
I even tried to add every single button in a group, expecting the focused button to change automatically, without calling lv_list_up(menu) or lv_list_down(menu).
Even like this one works, I feel like it’s very inelegant. From what I read in the code for lv_list, it seems that the buttons are added to an internal group, but I don’t understand how to access it.
Sorry if I missed something in the documentation, I didn’t find anything about lists and encoders.
Not so useful, but can give the idea of what I would like to obtain, maybe there are better suggestions than a list?
