How to make the focused menu's object visible in screen range?
I used the demo widgets from lvgl 8.3 within vs2019.
When I added more object(slider) beyond one screen can dispaly.I found that with a mouse wheel navigating to the object out of the screen, the object will not automatic to be updated in the display area of screen.
vs2019
8.3
I want to make the object focused be displayed in the visble area of the screen .
nothing can do but:
other function is in the file lv_example_menu_5.c of the demo library.
what I changed is the function below:
“Velocity1”~“Weight limit2” added in “sub_mechanics_page”
void lv_example_menu_5(void)
    lv_obj_t * menu = lv_menu_create(lv_scr_act());
    lv_color_t bg_color = lv_obj_get_style_bg_color(menu, 0);
    if(lv_color_brightness(bg_color) > 127) {
        lv_obj_set_style_bg_color(menu, lv_color_darken(lv_obj_get_style_bg_color(menu, 0), 10), 0);
    }else{
        lv_obj_set_style_bg_color(menu, lv_color_darken(lv_obj_get_style_bg_color(menu, 0), 50), 0);
    lv_menu_set_mode_root_back_btn(menu, LV_MENU_ROOT_BACK_BTN_ENABLED);
    lv_obj_add_event_cb(menu, back_event_handler, LV_EVENT_CLICKED, menu);
    lv_obj_set_size(menu, lv_disp_get_hor_res(NULL), lv_disp_get_ver_res(NULL));
    lv_obj_center(menu);
    lv_obj_t * cont;
    lv_obj_t * section;
    /*Create sub pages*/
    lv_obj_t * sub_mechanics_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_mechanics_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    lv_menu_separator_create(sub_mechanics_page);
    section = lv_menu_section_create(sub_mechanics_page);
    create_slider(section, LV_SYMBOL_SETTINGS, "Velocity", 0, 150, 120);
    create_slider(section, LV_SYMBOL_SETTINGS, "Acceleration", 0, 150, 50);
    create_slider(section, LV_SYMBOL_SETTINGS, "Weight limit", 0, 150, 80);
    create_slider(section, LV_SYMBOL_SETTINGS, "Velocity1", 0, 150, 120);
    create_slider(section, LV_SYMBOL_SETTINGS, "Acceleration1", 0, 150, 50);
    create_slider(section, LV_SYMBOL_SETTINGS, "Weight limit1", 0, 150, 80);
    create_slider(section, LV_SYMBOL_SETTINGS, "Velocity2", 0, 150, 120);
    create_slider(section, LV_SYMBOL_SETTINGS, "Acceleration2", 0, 150, 50);
    create_slider(section, LV_SYMBOL_SETTINGS, "Weight limit2", 0, 150, 80);
    lv_obj_t * sub_sound_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_sound_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    lv_menu_separator_create(sub_sound_page);
    section = lv_menu_section_create(sub_sound_page);
    create_switch(section, LV_SYMBOL_AUDIO, "Sound", false);
    lv_obj_t * sub_display_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_display_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    lv_menu_separator_create(sub_display_page);
    section = lv_menu_section_create(sub_display_page);
    create_slider(section, LV_SYMBOL_SETTINGS, "Brightness", 0, 150, 100);
    lv_obj_t * sub_software_info_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_software_info_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    section = lv_menu_section_create(sub_software_info_page);
    create_text(section, NULL, "Version 1.0", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_obj_t * sub_legal_info_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_legal_info_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    section = lv_menu_section_create(sub_legal_info_page);
    for(uint32_t i=0; i<15; i++){
        create_text(section, NULL, "This is a long long long long long long long long long text, if it is long enough it may scroll.", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_obj_t * sub_about_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_about_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    lv_menu_separator_create(sub_about_page);
    section = lv_menu_section_create(sub_about_page);
    cont = create_text(section, NULL, "Software information", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_software_info_page);
    cont = create_text(section, NULL, "Legal information", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_legal_info_page);
    lv_obj_t * sub_menu_mode_page = lv_menu_page_create(menu, NULL);
    lv_obj_set_style_pad_hor(sub_menu_mode_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    lv_menu_separator_create(sub_menu_mode_page);
    section = lv_menu_section_create(sub_menu_mode_page);
    cont = create_switch(section, LV_SYMBOL_AUDIO, "Sidebar enable", true);
    lv_obj_add_event_cb(lv_obj_get_child(cont, 2), switch_handler, LV_EVENT_VALUE_CHANGED, menu);
    /*Create a root page*/
    root_page = lv_menu_page_create(menu, "Settings");
    lv_obj_set_style_pad_hor(root_page, lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
    section = lv_menu_section_create(root_page);
    cont = create_text(section, LV_SYMBOL_SETTINGS, "Mechanics", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_mechanics_page);
    cont = create_text(section, LV_SYMBOL_AUDIO, "Sound", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_sound_page);
    cont = create_text(section, LV_SYMBOL_SETTINGS, "Display", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_display_page);
    create_text(root_page, NULL, "Others", LV_MENU_ITEM_BUILDER_VARIANT_1);
    cont = create_text(section, NULL, "About", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_about_page);
    cont = create_text(section, LV_SYMBOL_SETTINGS, "Menu mode", LV_MENU_ITEM_BUILDER_VARIANT_1);
    lv_menu_set_load_page_event(menu, cont, sub_menu_mode_page);
    lv_menu_set_sidebar_page(menu, root_page);
    lv_event_send(lv_obj_get_child(lv_obj_get_child(lv_menu_get_cur_sidebar_page(menu), 0), 0), LV_EVENT_CLICKED, NULL);
Would you have some good ideas
Just add a focus event on the slider, and scroll obj to the displayable area in the event handler:
static void on_focus(lv_event_t* e)
    lv_obj_t* obj = lv_event_get_current_target(e);
    lv_obj_scroll_to_view_recursive(obj, LV_ANIM_ON);
static lv_obj_t * create_slider(lv_obj_t * parent, const char * icon, const char * txt, int32_t min, int32_t max,
                                int32_t val)
    lv_obj_t * obj = create_text(parent, icon, txt, LV_MENU_ITEM_BUILDER_VARIANT_2);
    lv_obj_t * slider = lv_slider_create(obj);
    lv_obj_set_flex_grow(slider, 1);
    lv_slider_set_range(slider, min, max);
    lv_slider_set_value(slider, val, LV_ANIM_OFF);
    /*  add focus event */
    lv_obj_add_event_cb(slider, on_focus, LV_EVENT_FOCUSED, NULL);
    if(icon == NULL) {
        lv_obj_add_flag(slider, LV_OBJ_FLAG_FLEX_IN_NEW_TRACK);
    return obj;
Thanks.
I found that add this to the section is better.
lv_obj_set_scroll_snap_y(section, LV_SCROLL_SNAP_START);//LV_SCROLL_SNAP_CENTER);
Thanks for this, the on_focus method solved a related issue I was having!
When using lv_menu and exclusively button / encoder based navigation, setting the LV_OBJ_FLAG_SCROLL_ON_FOCUS flag generally works for normal menu items but isn’t ideal when the menu item contains something like a slider or switch that is the focused object instead of the whole menu item. In this case scroll on focus only moves to show the slider itself, which often leaves it hanging right at the bottom or top of the screen and cuts off the ends of the menu item container.
Using snapping also didn’t feel right, moving the menu beyond the top and bottom of where it should have been allowed to scroll, leaving large areas of whitespace when at the top or bottom of the menu. Perhaps LV_SCROLL_SNAP_CENTER would have worked if the menu was somehow infinitely scrollable like rollers can be, but that’s quite a lot of extra work…
By adjusting the on_focus function above to the following, it scrolls to show the whole menu item rather than just the slider or other focused object:
void on_focus(lv_event_t * e)
    lv_obj_t * obj = lv_event_get_current_target(e);
    lv_obj_scroll_to_view_recursive(lv_obj_get_parent(obj), LV_ANIM_ON);
I have tested it. It looks like awesome.
