I want to create an OSD using LVGL and need to make the screen transparent.
My OSD runs well in opaque situations.
If transparency is set, an exception will occur.
If set as follows:
#define LV_COLOR_DEPTH 32
#define LV_COLOR_SCREEN_TRANSP 1
lv_obj_set_style_bg_opa(lv_scr_act(), LV_OPA_TRANSP, LV_PART_MAIN);
lv_disp_set_bg_opa(NULL, LV_OPA_TRANSP);
The abnormal situation will result in the entire screen being blurred.
If set as follows:
lv_disp_get_default()->driver->screen_transp = 1;
The abnormal situation will be that the OSD is completely off display and can not see anything on OSD.
May I ask if there are any other methods I can try?
lvgl v8.3
