I want to design a switch with a small padding between the knob (the white circle) and the container.
SDL Simulator
branch release/v7
I’ve tried setting various parts of the style (mainly padding and margin), but to no avail. This is from my last attempt:
lv_obj_t *sw = lv_switch_create(lv_scr_act(), NULL);
lv_obj_set_style_local_bg_color(sw, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, LV_COLOR_GREEN);
lv_obj_set_style_local_bg_color(sw, LV_SWITCH_PART_INDIC, LV_STATE_DEFAULT, LV_COLOR_GREEN);
lv_obj_set_style_local_pad_bottom(sw, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_pad_top(sw, LV_SWITCH_PART_BG, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_pad_bottom(sw, LV_SWITCH_PART_INDIC, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_pad_top(sw, LV_SWITCH_PART_INDIC, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_margin_top(sw, LV_SWITCH_PART_KNOB, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_margin_bottom(sw, LV_SWITCH_PART_KNOB, LV_STATE_DEFAULT, 10);
lv_obj_set_style_local_bg_color(sw, LV_SWITCH_PART_KNOB, LV_STATE_DEFAULT, LV_COLOR_WHITE);
This is the result I’d like to reproduce:
And this is what I’m stuck with:
