How to make my UI transperent
I’m useing LVGL 9 to create a UI on a linux drm plane.
UI itself works for me.
I have gstreamer playing a video on the overlay plane and want to use LVGL to draw the UI over the video.
Radxa Zero 3W
9-master
I need the UI to be transperent where nothing is drawn (black background)
Changed the color format to be #define DRM_FOURCC DRM_FORMAT_ARGB8888
When useing modetest to set the alpha of the plane this affects all colors.
I run the a basic hello world menu.
int main(int argc, char **argv)
    // setup keybard inout from stdin
    set_stdin_nonblock();
    printf("WASD Navigation active (Q to quit)\n");
    /* Initialize LVGL. */
    /* Initialize libDRM */
    const char *device = "/dev/dri/card0";
    lv_display_t * disp = lv_linux_drm_create();
    lv_linux_drm_set_file(disp, device, -1);
    // Create a virtual keyboard input device
    lv_indev_t * kb_indev = create_virtual_keyboard();
    // Check if the virtual keyboard was created successfully
    if (kb_indev) {
        printf("Virtual keyboard created successfully!\n");
    } else {
        printf("Error: Could not create virtual keyboard!\n");
    /*Change the active screen's background color*/
    lv_obj_set_style_bg_color(lv_screen_active(), lv_color_hex(0x000000), LV_PART_MAIN);
    /*Create a white label, set its text and align it to the center*/
    lv_obj_t * label = lv_label_create(lv_screen_active());
    lv_label_set_text(label, "Hello world");
    lv_obj_set_style_text_color(lv_screen_active(), lv_color_hex(0xffffff), LV_PART_MAIN);
    while (1) {
        // Handle keyboard input
        handle_keyboard_input();
        lv_task_handler();
        //ui_tick();
        usleep(5000);  // Sleep for a short period to allow LVGL to update
    //lv_linux_run_loop();
    //sleep(50);
    return 0;
changes in lv_conf.h
#define LV_COLOR_DEPTH 32
#define LV_USE_LINUX_DRM        1
#define LV_USE_EVDEV    1
Meanwhile i found this in the documentation: is Widget Basics — LVGL documentation
However setting this does not change anything.
Narrowed it down further:
This gives me a transperent label:
While this gives me a non transparent rectangle:
lv_obj_t *obj = lv_obj_create(lv_screen_active());
I have to add
lv_obj_set_style_opa(obj, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
to make the rectangle transparant.
However when doing this in EEZ-Studio this does not work.
