So.
After many hours to make some tests, I can say :
atof() function DIDN’T work on my board.
I use instead the sscanf function.
here the code work as i want :
include "ui.h"
void calcul(lv_event_t* e) {
const char* str1 = lv_label_get_text(ui_LabelVal1);
const char* str2 = lv_label_get_text(ui_LabelVal2);
float num1, num2;
sscanf(str1, "%f", &num1);
sscanf(str1, "%f", &num2);
float result = num1 * num2;
lv_label_set_text_fmt(ui_LabelResult, "%.3f", result);
Problem solved ![]()
