How to make an object non-editable
Hi there, I am trying to make a normal object (which contains two labels) clickable with an encoder.
Once I create the object, I have a callback registered for LV_EVENT_SHORT_CLICKED. However, to trigger my callback, I need to click the object twice. (It seems as though I need to activate edit mode, then click again to get the “LV_EVENT_SHORT_CLICKED” event to be sent.
Furthermore, once I am in edit mode, I cant for the life of me return to navigate mode without manually doing that in the callback. (So I get stuck within the object)
I am using an STM32F769 on a custom board, with CubeIDE
Version 8.1+
I want my my objects to act like buttons (regarding navigation and clicking).
I dont want to be able to “edit” the object, I just want it to trigger the “clicked” callback, and then I want to continue navigating, just like a normal button would.
So I have my objects, all underneath one another. I have tried setting various flags on the objects without success.
Code to reproduce:
This is where I create my objects:
void Display_BuildSettingsMenu(lv_event_t * e)
	//Clear group of all objects
	lv_group_remove_all_objs(TestmenuGroup);
	//Create the array of setting items
	for(uint8_t i = 0; i < Settings_Count; i++)
		//Create an object
		Display_SettingsObjects[i] = lv_obj_create(lv_win_right_main_buttons);
		//Set the object size / align
		lv_obj_set_width(Display_SettingsObjects[i], LV_PCT(100));
		lv_obj_set_height(Display_SettingsObjects[i], 30);
		lv_obj_align(Display_SettingsObjects[i], LV_ALIGN_CENTER, 0, 0);
		//Reduce padding
		lv_obj_set_style_pad_all(Display_SettingsObjects[i], 2, 0);
		//Add the first label (name of the setting)
		lv_obj_t * child1 = lv_label_create(Display_SettingsObjects[i]);
		lv_label_set_text(child1, TestJigSettings[i].Name);
		//set the width of the name label
		lv_obj_set_width(child1, LV_PCT(65));
		lv_obj_align(child1, LV_ALIGN_LEFT_MID, 0, 0);
		//Convert settings value to text for the second label
		char tempSettingText[MAX_SETTING_TEXT_LENGTH];
		Display_getSettingText(TestSettings[i].Type, TestSettings[i].Current, TestSettings[i].Options, TestSettings[i].OptionCount, tempSettingText);
		//Add the second label
		lv_obj_t * child2 = lv_label_create(Display_SettingsObjects[i]);
		lv_label_set_text(child2, tempSettingText);
		//set the width
		lv_obj_set_width(child2, LV_PCT(30));
		lv_obj_align(child2, LV_ALIGN_RIGHT_MID, 0, 0);
		//Add the parent object to the group
		lv_group_add_obj(TestmenuGroup, Display_SettingsObjects[i]);
		//Enable scrolling
		lv_obj_add_flag(Display_SettingsObjects[i], LV_OBJ_FLAG_SCROLL_ON_FOCUS);
		//Make clickable
		lv_obj_add_flag(Display_SettingsObjects[i], LV_OBJ_FLAG_CLICK_FOCUSABLE);
		//Add the callback for the menu item
		lv_obj_add_event_cb(Display_SettingsObjects[i], Display_EditSetting, LV_EVENT_SHORT_CLICKED, &TestJigSettings[i]);
	//Set indevices
	lv_indev_set_group(MyInputDevice, TestmenuGroup);
	lv_indev_set_group(MyInputDevice2, TestmenuGroup);
	//focus the first setting
	lv_group_focus_obj(Display_SettingsObjects[0]);
The callback “Display_EditSetting” is only called once I click one of the objects twice. Then I get stuck within that object (I assume in edit mode)
In lv_indev.c about 1035 lines, there is a judgment statement for determining whether the object is editable and scrollable, if the object is editable or scrollable, it will send a series of complex logic to the object, including entering the edit mode; If it’s not an editable or scrollable object, simple click and release events are sent. All you need to do is remove the scrollable with a lv_obj_remove_flag
