How to make a triangle needle in gauge with littlevgl?
Now,the needle of the gauge is always a line,How can we make a triangle needle? Do you have any suggest?
Unfortunately, it’s not supported right now.
In v6.0 (will be released in a few weeks) there is an image rotate feature. With this, you can create a custom gauge by using only the gauge’s background and manually rotate a needle image on it.
The current documentation of v6.0 is available here: https://littlevgl.com/sphinx/index.html
The latest development version is in the dev-6.0 branch.
Ok,thanks.
I will try it.
So to rotate the needle in v6 it needs a canvas and v7 does it directly?
It’s true for the images. I started to work on a feature to use an image as a needle in dev-7.0.
It should be available next week.
