I tried to disable gesture and event propagation to the parent, but it didn’t work properly
lv_obj_t * rect_1,* rect_2;
static void drag_event_handler(lv_event_t * e)
lv_indev_t * indev = lv_indev_active();
if(indev == NULL) return;
lv_point_t vect;
lv_indev_get_vect(indev, &vect);
int32_t x = lv_obj_get_x_aligned(obj) + vect.x;
int32_t y = lv_obj_get_y_aligned(obj) + vect.y;
lv_obj_set_pos(obj, x, y);
static void bagua_create(lv_obj_t * parent)
rect_1 = lv_obj_create(parent);
lv_obj_set_size(rect_1,150,150);
lv_obj_set_style_bg_color(rect_1,lv_palette_main(LV_PALETTE_BLUE),0);
lv_obj_add_flag(rect_1,LV_OBJ_FLAG_IGNORE_LAYOUT);
lv_obj_remove_flag(rect_1,LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_remove_flag(rect_1,LV_OBJ_FLAG_GESTURE_BUBBLE);
rect_2 = lv_obj_create(parent);
lv_obj_set_size(rect_2,150,150);
lv_obj_set_style_bg_color(rect_2,lv_palette_main(LV_PALETTE_RED),0);
lv_obj_add_flag(rect_2,LV_OBJ_FLAG_IGNORE_LAYOUT);
lv_obj_remove_flag(rect_2,LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_remove_flag(rect_2,LV_OBJ_FLAG_GESTURE_BUBBLE);
lv_obj_align_to(rect_2,rect_1,LV_ALIGN_OUT_RIGHT_MID,0,0);
lv_obj_add_event_cb(rect_1,drag_event_handler, LV_EVENT_PRESSING, NULL);
lv_obj_add_event_cb(rect_2,drag_event_handler, LV_EVENT_PRESSING, NULL);
录制_2024_03_16_16_40_50_397.zip (1.3 MB)
