gcc 。 I use Gui-Guider软件(版本1.7.0-GA) to generate my ui code/
lvgl版本是v8.3.10
how to support argb4444( 2 bytes per pixel) in lvgl?
The basic situation of my code is: the macro define in lvgl_conf.h is below:
#define LV_COLOR_DEPTH 32
#define LV_COLOR_SCREEN_TRANSP 1
I has defined set_px_cb_ex function set to lv_disp_drv_t::set_px_cb,as the code show below,
but when I show the the frame data from flush_cb callback , some ui show error. example the label is transparent on the edge of the word. and some has opa image is show error.
void set_px_cb_ex(struct _lv_disp_drv_t * disp_drv, uint8_t * buf, lv_coord_t buf_w,
lv_coord_t x, lv_coord_t y, lv_color_t color, lv_opa_t opa) {
LV_LOG_INFO("set_px_cb_ex buf=%p",(void *)buf);
// 计算在缓冲区中的索引
size_t index = (y * buf_w + x) * 2; // 每个像素 2 字节(ARGB4444)
// 从 lv_color_t 中提取 RGB 值
uint8_t r = (lv_color_to32(color) >> 16) & 0xFF; // 红色
uint8_t g = (lv_color_to32(color) >> 8) & 0xFF; // 绿色
uint8_t b = lv_color_to32(color) & 0xFF; // 蓝色
// 按比例缩放到 4 位值
uint8_t a = (opa * 15) / 255; // Alpha,按比例缩放至 4 位
uint8_t r4 = (r * 15) / 255; // 红色,按比例缩放至 4 位
uint8_t g4 = (g * 15) / 255; // 绿色,按比例缩放至 4 位
uint8_t b4 = (b * 15) / 255; // 蓝色,按比例缩放至 4 位
// 组合成 ARGB4444 格式
uint16_t pixel = (a << 12) | (r4 << 8) | (g4 << 4) | b4;
// 写入缓冲区
buf[index] = pixel & 0xFF; // 低字节
buf[index + 1] = (pixel >> 8) & 0xFF; // 高字节
* STATIC FUNCTIONS
* Initialize the Hardware Abstraction Layer (HAL) for the Littlev graphics library
static void hal_init(void)
/* Use the 'monitor' driver which creates window on PC's monitor to simulate a display*/
monitor_init();
/*Create a display buffer*/
static lv_disp_draw_buf_t disp_buf1;
static lv_color_t buf1_1[480 * 10];
LV_LOG_INFO("hal_init buf1_1=%p",(void *)buf1_1);
lv_disp_draw_buf_init(&disp_buf1, buf1_1, NULL, 480 * 10);
/*Create a display*/
disp_drv.draw_buf = &disp_buf1;
disp_drv.flush_cb = monitor_flush;
disp_drv.set_px_cb = set_px_cb_ex;
disp_drv.hor_res = MONITOR_HOR_RES;
disp_drv.ver_res = MONITOR_VER_RES;
#if LV_COLOR_SCREEN_TRANSP == 1
disp_drv.screen_transp = 1;
/* Add the mouse as input device
* Use the 'mouse' driver which reads the PC's mouse*/
mouse_init();
lv_indev_drv_init(&indev_drv); /*Basic initialization*/
indev_drv.read_cb = mouse_read; /*This function will be called periodically (by the library) to get the mouse position and state*/
lv_indev_t * mouse_indev = lv_indev_drv_register(&indev_drv);
/* Tick init.
* You have to call 'lv_tick_inc()' in periodically to inform LittelvGL about how much time were elapsed
* Create an SDL thread to do this*/
SDL_CreateThread(tick_thread, "tick", NULL);
void setup_scr_screen(lv_ui *ui)
//Write codes screen
ui->screen = lv_obj_create(NULL);
lv_obj_set_size(ui->screen, 480, 320);
lv_obj_set_scrollbar_mode(ui->screen, LV_SCROLLBAR_MODE_OFF);
//Write style for screen, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_bg_opa(ui->screen, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes screen_cont_1
ui->screen_cont_1 = lv_obj_create(ui->screen);
lv_obj_set_pos(ui->screen_cont_1, 0, 0);
lv_obj_set_size(ui->screen_cont_1, 480, 320);
lv_obj_set_scrollbar_mode(ui->screen_cont_1, LV_SCROLLBAR_MODE_OFF);
//Write style for screen_cont_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_border_width(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_radius(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_img_src(ui->screen_cont_1, &_bg_480x320, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_img_opa(ui->screen_cont_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(ui->screen_cont_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write codes screen_label_1
ui->screen_label_1 = lv_label_create(ui->screen_cont_1);
lv_label_set_text(ui->screen_label_1, "hello");
lv_label_set_long_mode(ui->screen_label_1, LV_LABEL_LONG_WRAP);
lv_obj_set_pos(ui->screen_label_1, 182, 139);
lv_obj_set_size(ui->screen_label_1, 138, 55);
//Write style for screen_label_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_border_width(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_radius(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_color(ui->screen_label_1, lv_color_hex(0xFFFFFF), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui->screen_label_1, &lv_font_montserratMedium_32, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_opa(ui->screen_label_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_letter_space(ui->screen_label_1, 2, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_line_space(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_text_align(ui->screen_label_1, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(ui->screen_label_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
//The custom code of screen.
//Update current screen layout.
lv_obj_update_layout(ui->screen);
Red indicates that the area is completely transparent
