How to let lines of chart be more smooth?
Hi,I’m learning about widget chart recently,and I’ve almost finished all demos according to your codes.
And then I want to try some new tests,I created a line-chart and cleared all points on lines of chart,but I found that it is kind of stiff between line and line.Looks like an unproper transition.
So,how to fix it and let lines act more smooth?I’m just curious.
LVGL 8.3.0
Be smooth,like said above.
    lv_obj_t *chart = lv_chart_create(lv_scr_act());
    lv_obj_set_size(chart, 200, 180);
    lv_obj_center(chart);
    lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
    lv_chart_set_div_line_count(chart, 0, 0);
    lv_obj_set_style_bg_opa(chart, LV_OPA_TRANSP, LV_PART_INDICATOR);
    lv_chart_set_point_count(chart, 10);
    lv_chart_series_t *s = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_PRIMARY_Y);
    int i;
    for (i = 0; i < 10; i++)
        lv_chart_set_next_value(chart, s, lv_rand(10, 99));
    lv_chart_set_zoom_x(chart, 800);
    lv_obj_set_style_clip_corner(chart, true, LV_PART_ITEMS);
    lv_obj_set_style_line_rounded(chart, true, LV_PART_ITEMS);
You can use LV_CHART_TYPE_CURVE in v9
