I’m getting linking errors when trying to call any of the demos.
ESP32S3 on Arduino 3.0 with Lovyan GFX
9.1.0
As the title says, just draw a dot/circle/anything on the scale at the appropriate position without drawing the arc. Alternatively I’d like a way to rotate an object around a radius.
I have tried with the knob but I don’t know how to style it. I have also tried making a very small arc, and drawing half a degree to each side of the current point also an arc with zero size.
However both these solution present a very bad problem, in that they both take far more cpu power (despite drawing very little) than just drawing the arc normally. I don’t understand why both of these are so cpu heavy compared to actually drawing a large arc.
I am defining the knob like this
#define TICK_DEG 4
lv_obj_t * arc;
static lv_obj_t * scale1;
void knobCreate(lv_obj_t* parent){
scale1 = lv_scale_create(parent);
lv_obj_set_size(scale1, 240, 240);
lv_scale_set_mode(scale1, LV_SCALE_MODE_ROUND_INNER);
lv_scale_set_post_draw(scale1, true);
lv_obj_set_style_clip_corner(scale1, true, 0);
lv_obj_update_layout(parent);
/*Scale 1*/
lv_obj_set_style_pad_all(scale1, -1, 0);
arc = lv_arc_create(scale1);
lv_obj_remove_style(arc, NULL, LV_PART_KNOB);
//lv_obj_remove_style(arc, NULL, LV_PART_MAIN);
lv_obj_set_size(arc, lv_pct(100), lv_pct(100));
lv_obj_set_style_arc_opa(arc, 0, 0);
lv_obj_set_style_arc_width(arc, 20, LV_PART_INDICATOR);
lv_obj_set_style_arc_color(arc, lv_palette_main(LV_PALETTE_BLUE), LV_PART_INDICATOR);
//lv_obj_set_style_radius(scale1, LV_RADIUS_CIRCLE, 0);
lv_obj_remove_flag(arc, LV_OBJ_FLAG_CLICKABLE);
lv_scale_set_rotation(scale1, 270);
lv_obj_set_style_arc_color(arc,lv_palette_main(LV_PALETTE_RED),LV_PART_KNOB);
lv_obj_set_style_outline_width(arc, 1, LV_PART_KNOB);
lv_arc_set_knob_offset(arc, 0);
lv_arc_set_angles(arc, 270.0f,270.0f);
lv_arc_set_mode(arc,LV_ARC_MODE_SYMMETRICAL);
lv_arc_set_rotation(arc,270);
lv_arc_set_bg_angles(arc, 0, 360);
lv_arc_set_range(arc,0,360);
lv_arc_set_value(arc,0);
//printf("range: %d\n",lv_arc_get_value(arc));
lv_scale_set_angle_range(scale1, 360);
lv_scale_set_range(scale1,0, 360);
lv_scale_set_total_tick_count(scale1, 360);
lv_scale_set_major_tick_every(scale1, TICK_DEG);
lv_scale_set_label_show(scale1, false);
lv_obj_set_style_length(scale1, 0, LV_PART_ITEMS);
lv_obj_set_style_length(scale1, 10, LV_PART_INDICATOR);
I am then setting the location with
shaftAngleDeg >= 0 ? lv_arc_set_angles(arc, shaftAngleDeg,shaftAngleDeg) : lv_arc_set_angles(arc, 360+shaftAngleDeg,360+shaftAngleDeg);
Calling this does work, the knob shows, but no arc is drawn. But it heavily drops frames to the point of being unusable.
but as mentioned above, if I do
shaftAngleDeg >= 0 ? lv_arc_set_angles(arc, 0,shaftAngleDeg) : lv_arc_set_angles(arc, 360+shaftAngleDeg, 0);
Then it uses far less CPU power and while it drops some frames, it remains usable.
