I recently updated a project from lvgl v8 to v9.3 (and now v9.4), which has gone smoothly for the most part. The only difference I haven’t been able to figure out is how to mark a style property as “inheritable”.
I had this in v8:
- lv_style_set_prop_meta(style, s->prop, LV_STYLE_PROP_META_INHERIT);
which I was using to mark button text in the checked state the same colour as when it was in the unchecked state.
I would like to know what the right way to mark properties as inheritable is in v9.4.
The doco for inheritance in 9.3 and 9.4 appears to be gutted (Styles Overview - LVGL 9.4 documentation). The API described in older versions of the doco referred to the v8 API, which is no longer available.
I tried reading the style code but couldn’t find a setter for the style prop flags.
- MCU/MPU/Board: Not sure it matters, but it’s OpenBSD running on a PC with a touch screen.
- LVGL version: v9.4
