I’m trying to set a value of an arc in a timer, but I think I’m getting a crash. I want to use an arc as an indicator of a gauge value, from 1 to 100. I’ve created the screen and arc in SquareLine studio, latest versions.
RP2040 Connect, Arduino C++, IDE 2.x latest.
8.3.6
I want to be able to set the value of an arc (between 1 and 100) depending on the value of a variable, say an integer.
I have an int counter is a global (for testing).
For the screen that my arc is on, I have a SCREEN_LOADED event that starts an LVGL timer, set to fire every second. The timer works nicely. The callback function calls lv_arc_set_value(ui_VacuumPressure, counter);
The first time the timer gets called, all is good. The second time it gets called (counter == 2), it crashes. the label “ui_GaugeValueLabel” (see snippet below) updates correctly, then it crashes. If I comment out "lv_arc_set_value(ui_VacuumPressure, counter);", it works perfectly. If I have “lv_arc_set_value” use an absolute for the value, such as "lv_arc_set_value(ui_VacuumPressure, 50)", it doesn’t crash.
void updateGaugeScreen_timer(lv_timer_t *timer) {
counter++;
char buffer[4];
sprintf(buffer, "%d", counter);
lv_label_set_text(ui_GaugeValueLabel, buffer);
if (counter == 100) {
counter = 1;
## Screenshot and/or video
I don't have one - there doesn't seem to be an option to upload one.
