Descriptions
I’m use .bin files to save images, when i load large image it too slow
ESP32-S3
V8.3
I wanna load lager image .bin file quickly
increase drv->cache_size it not work still slow
static void * fs_open(lv_fs_drv_t * drv, const char * path, lv_fs_mode_t mode)
lv_fs_res_t res = LV_FS_RES_NOT_IMP;
void * f = NULL;
if(mode == LV_FS_MODE_WR) {
/*Open a file for write*/
f = "wb"; /*Add your code here*/
else if(mode == LV_FS_MODE_RD) {
/*Open a file for read*/
f = "rb"; /*Add your code here*/
else if(mode == (LV_FS_MODE_WR | LV_FS_MODE_RD)) {
/*Open a file for read and write*/
f = "rb+"; /*Add your code here*/
char filepath[256]={0};
sprintf(filepath, LV_FS_PATH "%s", path);
ESP_LOGI(TAG, "filepath: %s", filepath);
FILE* pf = fopen(filepath, f);
uint16_t size;
fseek(pf, 0, SEEK_END);
size = ftell(pf);
drv->cache_size = size;
rewind(pf);
ESP_LOGI(TAG, "file total size: %d", size);
if (pf == NULL)
ESP_LOGE(TAG, "open file failed ");
return pf;//fopen(filepath, f);
static lv_fs_res_t fs_read(lv_fs_drv_t * drv, void * file_p, void * buf, uint32_t btr, uint32_t * br)
ESP_LOGE(TAG, "real read file size: %ld ", btr);
*br = fread(buf, 1, btr, file_p);
return (int32_t)(*br) < 0 ? LV_FS_RES_UNKNOWN : LV_FS_RES_OK;
