I exported a Squareline project and imported it in arduino. Settings are fine for the display since it shows exactly what it’s supposed to. But I can’t get the touch to work, when I click the button, the graphic effect of it being pressed does not appear. Also, on the serial terminal, nothing shows when I press on the touch but its supposed to display X and Y values. All the pins are well set up in the User_setup.h file for the TFT_eSPI library and wiring is fine since the TestCalibration project is working as it should (display fine, touch working). So what am I missing here? Thanks in advance!!!
Arduino IDE on ESP32-S2-MINI Custom Dev Board (I created my own dev board for test purpose)
8.3.3
Make touch working so I can move ahead with my project!!!
Play with different pins, change SPI frequency, when to bed at 4am after watching tons of videos and tutorials…
Here is the ino file code:
#include <lvgl.h>
#include <TFT_eSPI.h>
#include "ui.h"
/*If you want to use the LVGL examples,
make sure to install the lv_examples Arduino library
and uncomment the following line.
#include <lv_examples.h>
/*Change to your screen resolution*/
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 480;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
uint16_t touchX = 0, touchY = 0;
bool touched = false;//tft.getTouch( &touchX, &touchY, 600 );
if( !touched )
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
void setup()
Serial.begin( 115200 ); /* prepare for possible serial debug */
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation( 2 ); /* Landscape orientation, flipped */
uint16_t calData[5] = { 250, 3433, 290, 3583, 2 };
tft.setTouch(calData);
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
/*Initialize the display*/
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
void loop()
delay(5);
Here is the User_setup.h file code:
#define USER_SETUP_INFO "User_Setup"
#define ILI9488_DRIVER
#define TFT_WIDTH 480
#define TFT_HEIGHT 320
#define TFT_MISO 19
#define TFT_MOSI 21
#define TFT_SCLK 18
#define TFT_CS 15 // Chip select control pin
#define TFT_DC 2 // Data Command control pin
#define TFT_RST 4 // Reset pin (could connect to RST pin)
#define TFT_BL 26 // LED back-light (only for ST7789 with backlight control pin)
#define TOUCH_CS 16 // Chip select pin (T_CS) of touch screen
#define LOAD_GLCD
#define SPI_FREQUENCY 20000000
#define SPI_READ_FREQUENCY 20000000
#define SPI_TOUCH_FREQUENCY 2500000
#define USE_HSPI_PORT
