When scrolled down to the end of table (or list), I’d like to get an event.
I used **LV_EVENT_SCROLL_END**
, but it all happened when I scrolled up or scrolled down to the end. How to get the event only when scrolled down?
You can check the scroll direction in the event with
if(lv_indev_get_scroll_dir(lv_indev_get_act()) == LV_DIR_BOTTOM)
I tried it, but only the LV_DIR_VER
event is occurred.
static void table_event_cb(lv_event_t * event)
if(lv_indev_get_scroll_dir(lv_indev_get_act()) == LV_DIR_BOTTOM )
if(code == LV_EVENT_SCROLL_END) {
else if(lv_indev_get_scroll_dir(lv_indev_get_act()) == LV_DIR_VER )
lv_obj_add_event_cb(win_content, table_event_cb, LV_EVENT_ALL, NULL);
Ah, you are right.
lv_point_t p;
lv_indev_get_vect(lv_indev_get_act(), &p);
tells the difference between the last and current point of the input device. You can check the sign of p.y
the decide the scroll direction.
That’s great. It works
lv_point_t p;
if(p.y < 0)
