Is there a way to get the name (or any other ID) for the current screen?
I know there is lv_scr_act(), but it doesn’t tell us the name of the screen?
For example, something like:
lv_obj_t * activeScreen = lv_scr_act();
if( lv_get_screen_name(activeScreen) == "ui_S2")
//do
Thanks in advance
Maybe try this.
lv_disp_get_scr_act(disp)
Hi
I found this post because I have the exact same question. Did you ever come up with a solution to this?
Thanks
Yes, I found a solution.
I declare a global variable:
char * currentScreen;
then on screen_load_start event i update the screen name.
if ( event_code == LV_EVENT_SCREEN_LOAD_START ) {
currentScreen = “ui_s4”;
//ui.c
// SCREEN: ui_Main
void ui_Main_screen_init(void);
void ui_event_Main( lv_event_t * e);
lv_obj_t *ui_Main;
if (lv_scr_act()==ui_Main)
do
For me works ok with Squareline
