How to get LV_EVENT_KEY events in navigation mode?
Get LV_EVENT_KEY event in navigation mode. You can only get LV_EVENT_KEY in edit mode.
M487KMCAN
V8.4
I want to get the LV_EVENT_KEY event in navigation mode so that I can implement the corresponding logic processing
static void screen_set_event_handler (lv_event_t *e)
    lv_event_code_t code    = lv_event_get_code(e);
    lv_ui           * ui    = lv_event_get_user_data(e);
    lv_obj_t        * obj   = lv_event_get_target(e);
    lv_group_t      * group = lv_obj_get_group(obj);
    switch (code) {
        case LV_EVENT_FOCUSED:
            if(lv_group_get_editing(group) == false){
                lv_obj_scroll_to_view(ui->screen_set_cont_sound, LV_ANIM_ON);
        break;
        case LV_EVENT_KEY:
            uint32_t key = lv_event_get_key(e);
            if(key == LV_KEY_ENTER) {
                lv_group_set_editing(group, false);
                Screen_Controller.Current_Page = SCREEN_PAGE_CH_MAIN;
        break;
        default:
            break;
## Screenshot and/or video
Hi @Linux-yzy, thank you for sending your question. Well, you need to create your callback before registering the indev.
For example, if you want to add a event to the current screen you just need :
static void screen_key_cb(lv_event_t * e)
 // Doing something.
lv_obj_add_event_cb(screen, screen_key_cb, LV_EVENT_KEY, NULL);
Take a look at the documentation:
