Hi
I’m using Slider with both value changed and long pressed Event. But the problem is in read callback it gets LV_INDEV_STATE_RELEASED state periodically. how to change the read callback to solve this problem. Actually I want to use Long Press of the Up & Down Button for Greater Increments Steps on Slider. by Pressing and holding it, it increments in 10 steps instead of 1 step per button press. beside this is there any other way that can implement this functionality?
Stm32f769igt6
8.2
Getting Long Press Event on Slider Up and Down Button. Finally Use that event for moving Slider Faster than one Step per button Press.
even by Commenting the data->state = LV_INDEV_STATE_RELEASED; It didn’t get the Long Press Event.
void Key_read_cb(lv_indev_drv_t * drv, lv_indev_data_t *data){
if(DOWN_B_F){
DOWN_B_F = false;
if(navigate_mode_f){
lv_group_focus_prev(g);
else{
data->key = LV_KEY_LEFT;
lv_group_set_editing(g,true);
}else if(UP_B_F){
UP_B_F = false;
lv_group_focus_next(g);
else{
data->key = LV_KEY_RIGHT;
}else if(OK_B_F){
OK_B_F = false;
data->key = LV_KEY_ENTER;
}else{
lv_obj_add_event_cb(ui_GeneratorNomPowSlider, ui_event_GeneratorNomPowSlider, LV_EVENT_ALL, NULL);
void ui_event_GeneratorNomPowSlider(lv_event_t * e)
lv_obj_t * target = lv_event_get_target(e);
if(event_code == LV_EVENT_LONG_PRESSED) {
GeneratorNomPowS_LPress(e);
// }else if(event_code == LV_EVENT_VALUE_CHANGED) {
// GeneratorNomPowS_VCH(e);
