How to get keypad event
i want to contral button by keypad,when i press key,keypad_callback() can get act_key,But i can’t get key event in my ta_event_cb().would you give some guidance
static bool keypad_callback(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
    uint last_key = 0;
    /*Get whether the a key is pressed and save the pressed key*/
    uint act_key = keypad_get_key();
    if(act_key != KEY_NONE)
        data->key=act_key;
        TRACE(DBG_TRACE_LVL,"%s,act_key=%d\r\n",__FUNCTION__,act_key);
        /*Translate the keys to LVGL control characters according to your key definitions*/
        switch(act_key)
            case KEY_DOWN:
                act_key = LV_KEY_DOWN;
                break;
            case KEY_UP:
                act_key = LV_KEY_UP;
                break;
            case KEY_CANCEL:
                act_key = LV_KEY_END;
                break;
            case KEY_CONFIRM:
                act_key = LV_KEY_ENTER;
                break;
            case KEY_DELETE:
                act_key = LV_KEY_DEL;
                break;
            case KEY_POWER:
                act_key = LV_KEY_HOME;
                break;
            default:
                break;
        last_key = act_key;
    data->key = last_key;
    /*Return `false` because we are not buffering and no more data to read*/
    return false;
static void ta_event_cb(lv_obj_t * ta, lv_event_t event)
    TRACE(DBG_TRACE_LVL,"%s-event=%d\r\n",__FUNCTION__,event);
        /* Focus on the clicked text area */
        if(kb != NULL)
            lv_keyboard_set_textarea(kb, ta);
    else if(event == LV_EVENT_INSERT) {
        const char * str = lv_event_get_data();
        if(str[0] == '\n') {
            //printf("Ready\n");
