Hi all, I’m trying to replicate a chart example I’ve seen in LVGL’s documentation. For reference, the example is called “Show cursor on the clicked point” and here’s the link to the page containing the example: Chart (lv_chart) — LVGL documentation. However, when I try to run the code, it gives me the error seen in the screenshot below - lv_draw_ctx_t is an unrecognized type.
Xilinx Zynq Development Board running eclipse through Xilinx SDK
8.1
I want to get the graph example to work so that when a user clicks on a point, a label will pop up indicating which point they clicked and cursors will be drawn to identify the axis (just like in the example).
I tried creating a label and ditching the lv_draw_ctx_t call altogether but that solution was not as elegant and does not give me the cursors.
#include "../../lv_examples.h"
#if LV_USE_CHART && LV_BUILD_EXAMPLES
static lv_obj_t * chart;
static lv_chart_series_t * ser;
static lv_chart_cursor_t * cursor;
static void event_cb(lv_event_t * e)
static int32_t last_id = -1;
if(code == LV_EVENT_VALUE_CHANGED) {
last_id = lv_chart_get_pressed_point(obj);
if(last_id != LV_CHART_POINT_NONE) {
lv_chart_set_cursor_point(obj, cursor, NULL, last_id);
else if(code == LV_EVENT_DRAW_PART_END) {
if(!lv_obj_draw_part_check_type(dsc, &lv_chart_class, LV_CHART_DRAW_PART_CURSOR)) return;
if(dsc->p1 == NULL || dsc->p2 == NULL || dsc->p1->y != dsc->p2->y || last_id < 0) return;
lv_coord_t * data_array = lv_chart_get_y_array(chart, ser);
lv_coord_t v = data_array[last_id];
char buf[16];
lv_snprintf(buf, sizeof(buf), "%d", v);
lv_point_t size;
lv_txt_get_size(&size, buf, LV_FONT_DEFAULT, 0, 0, LV_COORD_MAX, LV_TEXT_FLAG_NONE);
lv_area_t a;
a.y2 = dsc->p1->y - 5;
a.y1 = a.y2 - size.y - 10;
a.x1 = dsc->p1->x + 10;
a.x2 = a.x1 + size.x + 10;
lv_draw_rect_dsc_t draw_rect_dsc;
lv_draw_rect_dsc_init(&draw_rect_dsc);
draw_rect_dsc.bg_color = lv_palette_main(LV_PALETTE_BLUE);
draw_rect_dsc.radius = 3;
lv_draw_rect(dsc->draw_ctx, &draw_rect_dsc, &a);
lv_draw_label_dsc_t draw_label_dsc;
lv_draw_label_dsc_init(&draw_label_dsc);
draw_label_dsc.color = lv_color_white();
a.x1 += 5;
a.x2 -= 5;
a.y1 += 5;
a.y2 -= 5;
lv_draw_label(dsc->draw_ctx, &draw_label_dsc, &a, buf, NULL);
* Show cursor on the clicked point
void lv_example_chart_6(void)
chart = lv_chart_create(lv_scr_act());
lv_obj_set_size(chart, 200, 150);
lv_obj_align(chart, LV_ALIGN_CENTER, 0, -10);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_Y, 10, 5, 6, 5, true, 40);
lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_X, 10, 5, 10, 1, true, 30);
lv_obj_add_event_cb(chart, event_cb, LV_EVENT_ALL, NULL);
lv_obj_refresh_ext_draw_size(chart);
cursor = lv_chart_add_cursor(chart, lv_palette_main(LV_PALETTE_BLUE), LV_DIR_LEFT | LV_DIR_BOTTOM);
ser = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
uint32_t i;
for(i = 0; i < 10; i++) {
lv_chart_set_next_value(chart, ser, lv_rand(10, 90));
lv_chart_set_zoom_x(chart, 500);
lv_label_set_text(label, "Click on a point");
lv_obj_align_to(label, chart, LV_ALIGN_OUT_TOP_MID, 0, -5);
