How to fix calendar when touching date however mis-jumping to other month?
When touching for selecting date in the month on the calendar,
but sometime calendar sends mis-jumping signal and changes to other month. (as the following video)
How to fix this calendar’s mis-jumping ?
Thank you.
  • ESP32
  • lvgl 6.0.2
I don’t want the calendar occurs mis-jumping
to other month that doesn’t be clicked.
static lv_style_t style_header;
static lv_style_t style_header_pr;
static lv_style_t style_day_names;
static lv_style_t style_bg;
static lv_style_t style_inactive;
static lv_style_t style_week_box;
static lv_style_t style_today_box;
void create_calendar(lv_color_t color){
  lv_obj_t *calendar = lv_calendar_create(lv_scr_act(),NULL);
  lv_obj_set_size(calendar,320,240);
  lv_calendar_date_t today = { 2019, 8, 21 };
  lv_calendar_set_today_date (calendar, &today);
  lv_calendar_set_showed_date(calendar, &today);
  lv_obj_set_event_cb(calendar, [](lv_obj_t *calendar, lv_event_t event){
    if(event == LV_EVENT_CLICKED ){
      lv_calendar_date_t* pr_date = lv_calendar_get_pressed_date(calendar);
      if(pr_date) {
        Serial.printf("clicked : %02d/%02d/%04d\n", pr_date->day, pr_date->month, pr_date->year);
        lv_calendar_set_today_date (calendar, pr_date);
        lv_calendar_set_showed_date(calendar, pr_date);
  lv_style_copy( &style_header,     lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_HEADER));
  lv_style_copy( &style_header_pr,  lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_HEADER_PR));
  lv_style_copy( &style_day_names,  lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_DAY_NAMES));
  lv_style_copy( &style_bg,         lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_BG));
  lv_style_copy( &style_inactive,   lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_INACTIVE_DAYS));
  lv_style_copy( &style_week_box,   lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_WEEK_BOX));
  lv_style_copy( &style_today_box,  lv_calendar_get_style(calendar, LV_CALENDAR_STYLE_TODAY_BOX));
  style_header.body.main_color    = color;
  style_header.body.grad_color    = color;
  style_header.text.font          = &lv_font_roboto_22;
  style_header_pr.body.main_color = color;
  style_header_pr.body.grad_color = color;
  style_header_pr.text.font       = &lv_font_roboto_22;
  style_day_names.text.font       = &lv_font_roboto_22;
  style_bg.text.font              = &lv_font_roboto_22;
  style_inactive.text.font        = &lv_font_roboto_22;
  style_week_box.body.main_color = lv_color_mix(color, LV_COLOR_WHITE, 160);
  style_week_box.body.grad_color = lv_color_mix(color, LV_COLOR_WHITE, 160);
  style_week_box.text.font       = &lv_font_roboto_22;
  style_today_box.body.main_color = color;
  style_today_box.body.grad_color = lv_color_mix(color, LV_COLOR_BLACK, 128);
  style_today_box.text.font       = &lv_font_roboto_22;
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_HEADER,       &style_header);
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_HEADER_PR,    &style_header_pr);
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_DAY_NAMES,    &style_day_names);
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_BG,           &style_bg);
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_INACTIVE_DAYS,&style_inactive);
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_WEEK_BOX,     &style_week_box);
  lv_calendar_set_style(calendar, LV_CALENDAR_STYLE_TODAY_BOX,    &style_today_box);
Current showed month is set to August 2019.
At 00:08 on the video occurs mis-jumping to July 2019
What does the Serial.printf line output when it fails? Is it the same date that you clicked or a date in July?
When it fails, pr_date is NULL .
Then Serial.printf 's output doesn’t show anything.
Could it be a touchpad issue? Can you print all the read data in your touch_read function?
I use touch function from TFT_eSPI library.
The touchpad_read function is the following code.
static bool touchpad_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
//    static TP_Point p;
    uint16_t t_x = 0, t_y = 0;
    if(_tft->getTouch(&t_x, &t_y)) {
    } else {
    data->point.x = t_x;
    data->point.y = t_y;
    /*Return `false` because we are not buffering and no more data to read*/
    return false;
checkout this thread
there might be something useful in this thread
You should save the last pressed coordinate and use it as released. Or do not set the coordinates when the TP is released. For example:
    } else {
Issue is solved!
Thank you.
How to writing the touch pad driver and using it? I get it a little from the post.
Please open a new How-to post and fill out the template.
Hi, I have the same problem recently, but I’m sorry I can’t help you because I haven’t found a solution yet. When I find a solution, I will reply again
