I am trying to animate an image fading in. lv_obj_fade_in()
just makes the object appear immediately with no animation at all.
Is there anything that needs to be taken care of in order to use fade-in animations? I suspect that I need to enable LV_COLOR_SCREEN_TRANSP
in lv_conf.h
, but that requires setting LV_COLOR_DEPTH
to 32 and then RAM usage increases to a prohibitive level. I am currently using 8-bit colors for a monochrome display with 4-bit pixels.
Is there anyway in which I can make fade-in animations with 8-bit colors?
NXP MIMXRT1010
8.1
Fade in an image.
Using lv_obj_fade_in()
image = lv_img_create(lv_scr_act());
lv_img_set_src(image, &checkmark);
lv_obj_align(image, LV_ALIGN_BOTTOM_LEFT, 0, 0);
lv_obj_fade_in(image, 1000, 0);
