MAC + CLANG
9.3.0
I want that the buttons are equally filling out the space. The spaces between the buttons shall be the same as the gap to the container around. This is the example from LVGL. I reduced the size of the container to see how it behaves but then I realised that the buttons are not nice spaced in this containers and tried to fix it but failed. BTW is there anywhere a nice tutorial about that?
I tried out the Grid align options but they don’t do anything.
static int32_t col_dsc[] = {70, 70, 70, LV_GRID_ALIGN_SPACE_BETWEEN, LV_GRID_TEMPLATE_LAST};
static int32_t row_dsc[] = {50, 50, 50, LV_GRID_ALIGN_SPACE_BETWEEN, LV_GRID_TEMPLATE_LAST};
/*Create a container with grid*/
lv_obj_t * cont = lv_obj_create(lv_screen_active());
lv_obj_set_style_grid_column_dsc_array(cont, col_dsc, 0);
lv_obj_set_style_grid_row_dsc_array(cont, row_dsc, 0);
lv_obj_set_style_margin_all(cont, 0, 0);
lv_obj_set_style_pad_all(cont, 5, 0);
lv_obj_set_size(cont, 250, 200);
lv_obj_center(cont);
lv_obj_align(cont, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_layout(cont, LV_LAYOUT_GRID);
lv_obj_t * label;
lv_obj_t * obj;
uint8_t i;
for(i = 0; i < 9; i++) {
uint8_t col = i % 3;
uint8_t row = i / 3;
obj = lv_button_create(cont);
lv_obj_set_size(obj, 70, 50);
/*Stretch the cell horizontally and vertically too
*Set span to 1 to make the cell 1 column/row sized*/
lv_obj_set_grid_cell(obj, LV_GRID_ALIGN_STRETCH, col, 1, LV_GRID_ALIGN_STRETCH, row, 1);
label = lv_label_create(obj);
lv_label_set_text_fmt(label, "c%d, r%d", col, row);
lv_obj_center(label);
