How to enlarge the picture according to its length and width
In my project, I need to enlarge the jpg image according to the length and width of the image. Not to scale up.
Linux gcc
V7.4
Realize the picture display is enlarged according to the length and width.
I tried to imitate the interface of lv_img_set_zoom and wrote the interfaces of lv_img_set_zoom_x and lv_img_set_zoom_y respectively. However, when using it, it is still enlarged according to the same scale, and there is a ghost. (A picture that does not completely overlap is displayed on the interface twice). Can you provide some guidance? Looking forward to your reply, thank you very much.
Do you mean height and width? So set a width/height and the image should be zoomed to fit the set size?
Anyway, jpeg images can’t be zoomed directly because they are decompressed in a special way to save memory. And one limitation of this decompression method is transformations (zoom, rotate) can’t be performed.
Yes, I mean to set the picture display size by width and height. Regarding the decoding problem you mentioned, can I understand it here? Replace the JPEG decoding method with one that can obtain all the decoded data of JPEG or replace the decoding library that supports JPEG files to be read into the memory at one time. JPEG files can support scaling.
I’ve opened a future request about adding an option to decode the whole image:
Thank you very much, and look forward to an early resolution.
