How to enable FreeRTOS with LVGL 9.5 running on STM32N6570-DK board?
Hi everyone,
I am working on the STM32N6570-DK board and trying to run LVGL v9.5 with FreeRTOS, but I am facing issues integrating both properly.
What I have done so far:
  • Enabled FreeRTOS (CMSIS-RTOS v2)
  • Integrated LVGL v9.5 into the project
  • Initialized display and LVGL successfully (basic UI works without RTOS)
Issue:
  • When I enable FreeRTOS and run LVGL inside a task, and display behaves unexpectedly
  • It shows garbage pixels on display
  • Suspecting issues with:
    • lv_timer_handler() execution timing
    • Thread safety / mutex handling
    • Tick increment (lv_tick_inc) integration
What I tried:
  • Running lv_timer_handler() in a dedicated task with delay
  • Using mutex (xSemaphore) for LVGL calls
  • Checking stack size and task priority
Questions:
  1. What is the correct way to integrate LVGL 9.5 with FreeRTOS?
  2. How should lv_timer_handler() and lv_tick_inc() be handled in RTOS?
  3. Is there any official or recommended template for STM32N6 series?
  4. Are there any specific configurations required for STM32N6570-DK?
Additional Info:
  • MCU: STM32N657
  • LVGL Version: 9.5
  • RTOS: FreeRTOS (CMSIS v2)
Any guidance or working example would be really helpful.
Thanks in advance!
I mean this is still valid Operating system and interrupts — LVGL documentation
and primary you dont require lv_tick_inc , but hw based timer for lv_tick get
for example in arduino ESP simple is
lv_tick_set_cb(millis);
and main idea is place all lvgl parts in one task. Otherwise as describe docu.
Speaking from experience using the ThreadX RTOS,
If you are sure that you are initializing LVGL correctly, and your flush callback works, you should call lv_timer_handler() from your thread’s (I suppose FreeRTOS calls them ‘tasks’) main loop.
lv_tick_inc() should be called from an interrupt where you can fairly accurately gaurantee the ticks you need. So lv_tick_inc(1) from a 1000hz timer interrupt for instance.
Do not bother with multithreading LVGL itself, so long as you call all LVGL functions from other LVGL functions, it should work fine.
@Radhika-Changela Have you enabled FreeRTOS on lv_conf.h?
https://docs.lvgl.io/9.5/integration/rtos/freertos.html
Yes! I enabled LV_USE_FREERTOS in lv_conf.h
I have successfully integrated LVGL on the STM32N6570-DK board with FreeRTOS enabled (LV_USE_FREERTOS = 1). The basic UI works correctly.
However, when I run the LVGL benchmark demo, it completes successfully, but I observe tearing artifacts, especially with complex UI objects.
System Setup:
  • MCU: STM32N6570-DK (Cortex-M55)
  • OS: FreeRTOS
  • LVGL: (mention your version here)
  • Display driver: lv_st_ltdc.c
  • Rendering mode: Direct rendering
  • Buffering:
    • Single framebuffer
    • Size: 800 × 480 × 2 (full screen)
LVGL Configuration:
  • LV_USE_FREERTOS = 1
  • LVGL task is created as the default task in app_freertos.c
  • lv_timer_handler() is called inside the idle loop
Issue:
  • No crash or functional issue
  • Benchmark demo runs fully
  • Visible tearing occurs, especially during heavy UI updates
What I Tried:
  • Verified display initialization
  • Using LTDC driver from LVGL (lv_st_ltdc.c)
  • Single full-size buffer with direct mode
Question:
What could be the reason for tearing in this setup, and how can I fix it?
Additional Info:
I have attached the following files for reference:
  • main.c
  • app_freertos.c
  • lvgl_port.c
  • lv_st_ltdc.c
lvgl_port.c (2.7 KB)
main.c (30.4 KB)
lv_st_ltdc.c (11.0 KB)
@Radhika-Changela , great job. Are you interested in creating a tutorial about this integration for the LVGL Blog?
If you’re interested, create documentation in Google Docs and share it with the LVGL Team.
Hello @Radhika-Changela
Could you share app_freertos.c ? It is missing from your last reply.
Best regards
rom_st
this config exactly result to tearing and glitchs…
