I’m trying to enable the dark theme in the SDL/PC/Simulator Demo to no avail. Should this be possible “out of the box” (only changing the relevant define to 1), or is there more to be done to accomplish this?
N/A - SDL simulator; using make within the VSCode project.
v8.0.0 (commit c597d25)
Enable dark theme for the SDL Demo.
Changed #define LV_THEME_DEFAULT_DARK 0 to #define LV_THEME_DEFAULT_DARK 1. Also copied lv_conf.h to /ui/simulator/inc/ with no change. Using the preprocessor suggestion here, it appears to be defined properly (based on lv_conf.h), but I see no change in the demo app. Should the dark theme be usable in the demo?
Check out the demo project linked above (commit 10101817), change #define LV_THEME_DEFAULT_DARK 0 in lv_conf.h to #define LV_THEME_DEFAULT_DARK 1 then compile/debug.
