How to draw the line meter
STM32F7
v7.9
draw the line meter as attached
Try the gauge obj, but have no idea to do
line_meter
Hi, embeddedt,
Is the above meter too complex? How a about the below , the one have only one scale. It is normal used in the instrument to repalce the old mechanical one. The difficult is to just refresh the area the needle take. I tried adding a window on the gauge by setting a small obj size, but hard to control the outlook. Is there any sample code for such meter?
Happy New Year!
This one is much simpler. It can be done with one gauge object and a label on top. I would start with this example and adapt it. To adjust the angle you would change the scale.
Hi, embeddedt,
Many Thanks!
I had tried and it worked, but there have large blank space in the left and right. How to freely adjust the visualable area ? Is there any mask can be apply to an object beside the obj size?
Best Regards,
Try playing around with the padding or margin style properties.
Hi, embeddedt,
It works.
Thanks & Best Regards,
