How to draw a perfect circle?
LVGL Version…
8.3.9
What I want to…
I want to draw a perfect circle including :
  • the center point : lv_point_t point = {100,100}
  • the radius: int radius = 50
  • the line width: int line_width = 2
Unfortunately, I found that LVGL does not provide a direct interface for drawing circles. I have also tried using the arc to achieve a similar function, but the result was not satisfactory. :upside_down_face:
So what should I do to achieve this in detail?
Just create an empty lv_obj. Set its position (100, 100) and size (50?).
Give it a background color/opacity and set its RADIUS style property to either 50 or LV_RADIUS_CIRCLE.
EDIT: just realized you wanted to create a circl with just a line around it. Create an object of size 50, set the radius style property, set background opacity to 0 and then set the border with to 2 and color to whatever you want. See the documentation on styles:
https://docs.lvgl.io/8.4/overview/coords.html#using-styles
I sincerely appreciate your prompt and effective solution. As a beginner in LVGL programming, I am very grateful for your timely response and assistance in resolving my issues. Thank you very much! :smiling_face_with_three_hearts:
If you like to be more adventurous, you can use trigonometry too :slight_smile:
x1 = x + r * Cos (θ)
y1 = y + r * Sin (θ)
where
  • angle θ, goes from 0 deg to 360 degree converted to radian.
  • radian θ = deg θ * (3.14 / 180.0)
  • r is the radius of the circle
corner-angle
Yeah! I know that. Just don’t want to build from scratch, (because I’m so lazy… :wink:
No matter what, I’m still very thankful to you, man.
