I’m using a canvas (lv_canvas_create) so I can draw pixels to a canvas. It uses a static buffer to store the pixels. This way I can draw traces in real-time. I tried lv_chart but it updated way to slow. This works great in terms of update speed. I draw multiple traces at once. But, how can i draw a grid? I tried lv_line, but i didn’t manage to draw a grid with it. I used rectangle objects with a with of 0 for vertical lines and a height of 0 for vertical lines of the grid. That works as expected, but then always their will be a ‘crash’ (program doesn’t reacts anymore) when the mouse clicks some other lvgl object, like a drop down or so. That problem disappears when I only draw verticals or only horizontals. So, apparently, it only crashes when the rectangles (used as lines) cross.
The only way that I managed to draw the grid was by using the pixel method to draw the grid lines too. But then, the traces will ‘paint through’ these lines as well. So, after some time, the grid lines get ‘eaten up’.
How should I proceed? What is the best way to tackle this problem?
What platform are you using
Code is running on both linux and Windows using SDL2
9.3.0
Draw a grid (lines, like divisions) and draw real time traces that don’t interfere with the grid lines while not using lv_chart
a) Drawing everything on a canvas, b) drawing lines with lv_line and c) using a object to draw a rectangles with 0 width or height to simulate a horizontal and vertical line.
A code snipped:
void View::drawRectangle(lv_obj_t *canvas, int32_t x, int32_t y, int32_t width, int32_t height, lv_color_t color)
lv_obj_t * rect1 = lv_obj_create(canvas);
lv_obj_add_style(rect1, &style_views_rectangle, LV_STATE_DEFAULT | LV_PART_MAIN);
lv_obj_set_pos(rect1, x, y);
lv_obj_set_size(rect1, width, height);
lv_obj_set_style_border_color(rect1, color, LV_STATE_DEFAULT | LV_PART_MAIN);
void View::drawGrid(lv_obj_t *canvas, int32_t x, int32_t y, int32_t width, int32_t height, lv_color_t color)
float dx;
float dy;
int32_t i_x;
int32_t i_y;
for (int32_t i = 0; i < NUMBER_OF_DIVISIONS; i++)
// Vertical lines
dx = (float)width / (float)10;
i_x = round(dx * i);
drawRectangle(canvas, x + i_x, y, 1, height, color);
// Horizontal lines
dy = (float)height / (float)10;
i_y = round(dy * i);
drawRectangle(canvas, x, y + i_y, width, 1, color);
