How to draw a dynamic icon
how to draw a icon then update it dynamic.such as battery icon
Hi
You can create an img by using lv_img_create and update its image whenever you want by using lv_img_set_src.
Depends on the situation using lv_img_set_offset_x and lv_img_set_offset_y are good too.
Also, don’t forget to enable its click feature by lv_obj_set_click as for img objects click is disabled by default.
PS:
It would be better to specify your need and explain more about it, so we can help you better.
