I want to implement the way of dragging the scroll bar.
BLE MCU(ARM)
About the Scrollbar, I don’t find the method of dragging the scroll bar in the source code. I think it is necessary to create a scroll bar control, because the control can be set to drag.
lv_obj_set_drag(ScrollbarControl, true);
The usual solution is to ensure that the scrollable container with the objects is underneath the scrollbar instead of padded away from it (like how you have it). If you really want padding then apply it to the objects within the container.
All scrolling is handled by the scrollable container, so you need that underneath the scrollbar to give the effect of what you want.
