How to do monochrome (LV_COLOR_FORMAT_I1) image rendering on lvgl v9
Code
I am working on a project that should do image rendering for both rgb888( 24 bit per pixel) and I1(1 bit per pixel) using lvgl.
I am facing issue in image rendering with LV_COLOR_FORMAT_I1(version 9.2).
How to solve this issue?
LV_COLOR_FORMAT_I1 format requires LV_DRAW_SW_SUPPORT_ARGB8888 to be enabled in lv_conf.h
