How to display the value on a linear scale (LV_SCALE_MODE_VERTICAL_RIGHT)
I would like to use the lv_scale widget to display temperature values like a normal mercury thermometer. I have adapted the scale_2 example code, but I am unable to display the actual value. It draws the thermometer, but not the current temperature value.
I am using a ESP32 on a Cheap Yellow Display (CYD)
I am using lvgl 9.1.0 with Arduino IDE 2.3.2
I would like the scale to show a line indicating the current temperature, not just the scale.
I have adapted the examples. I can confirm that the callback function “set_needle_line_value” is called. The serial monitor prints the values.
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <XPT2046_Touchscreen.h>
// The CYD touch uses some non default
// SPI pins
#define XPT2046_IRQ 36
#define XPT2046_MOSI 32
#define XPT2046_MISO 39
#define XPT2046_CLK 25
#define XPT2046_CS 33
SPIClass touchscreenSpi = SPIClass(VSPI);
XPT2046_Touchscreen touchscreen(XPT2046_CS, XPT2046_IRQ);
uint16_t touchScreenMinimumX = 200, touchScreenMaximumX = 3700, touchScreenMinimumY = 240,touchScreenMaximumY = 3800;
/*Set to your screen resolution*/
#define TFT_HOR_RES   320
#define TFT_VER_RES   240
/*LVGL draw into this buffer, 1/10 screen size usually works well. The size is in bytes*/
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
#if LV_USE_LOG != 0
void my_print( lv_log_level_t level, const char * buf )
    LV_UNUSED(level);
    Serial.println(buf);
    Serial.flush();
/* LVGL calls it when a rendered image needs to copied to the display*/
void my_disp_flush( lv_display_t *disp, const lv_area_t *area, uint8_t * px_map)
    /*Call it to tell LVGL you are ready*/
    lv_disp_flush_ready(disp);
/*Read the touchpad*/
void my_touchpad_read( lv_indev_t * indev, lv_indev_data_t * data )
  if(touchscreen.touched())
    TS_Point p = touchscreen.getPoint();
    //Some very basic auto calibration so it doesn't go out of range
    if(p.x < touchScreenMinimumX) touchScreenMinimumX = p.x;
    if(p.x > touchScreenMaximumX) touchScreenMaximumX = p.x;
    if(p.y < touchScreenMinimumY) touchScreenMinimumY = p.y;
    if(p.y > touchScreenMaximumY) touchScreenMaximumY = p.y;
    //Map this to the pixel position
    data->point.x = map(p.x,touchScreenMinimumX,touchScreenMaximumX,1,TFT_HOR_RES); /* Touchscreen X calibration */
    data->point.y = map(p.y,touchScreenMinimumY,touchScreenMaximumY,1,TFT_VER_RES); /* Touchscreen Y calibration */
    Serial.print("Touch x ");
    Serial.print(data->point.x);
    Serial.print(" y ");
    Serial.println(data->point.y);
lv_obj_t * needle_line;
lv_obj_t * scale;
static void set_needle_line_value(void * obj, int32_t v)
  Serial.print("Value: ");
  Serial.println(v);
    lv_scale_set_line_needle_value((lv_obj_t *)obj, needle_line, 10, v);
void lv_example_scale_2(void)
    scale = lv_scale_create(lv_screen_active());
    lv_obj_set_size(scale, 60, 200);
    lv_scale_set_label_show(scale, true);
    lv_scale_set_mode(scale, LV_SCALE_MODE_VERTICAL_RIGHT);
    lv_obj_center(scale);
    lv_scale_set_total_tick_count(scale, 11);
    lv_scale_set_major_tick_every(scale, 2);
    lv_obj_set_style_length(scale, 10, LV_PART_INDICATOR);
    lv_obj_set_style_length(scale, 5, LV_PART_ITEMS);
    lv_scale_set_range(scale, 0, 50);
    static const char * custom_labels[] = {"0 °C", "10 °C", "20 °C", "30 °C", "40 °C", "50 °C", NULL};
    lv_scale_set_text_src(scale, custom_labels);
    static lv_style_t indicator_style;
    lv_style_init(&indicator_style);
    /* Label style properties */
    lv_style_set_text_font(&indicator_style, LV_FONT_DEFAULT);
    lv_style_set_text_color(&indicator_style, lv_palette_darken(LV_PALETTE_GREEN, 3));
    /* Major tick properties */
    lv_style_set_line_color(&indicator_style, lv_palette_darken(LV_PALETTE_GREEN, 3));
    lv_style_set_width(&indicator_style, 10U);      /*Tick length*/
    lv_style_set_line_width(&indicator_style, 2U);  /*Tick width*/
    lv_obj_add_style(scale, &indicator_style, LV_PART_INDICATOR);
    static lv_style_t minor_ticks_style;
    lv_style_init(&minor_ticks_style);
    lv_style_set_line_color(&minor_ticks_style, lv_palette_lighten(LV_PALETTE_GREEN, 2));
    lv_style_set_width(&minor_ticks_style, 5U);         /*Tick length*/
    lv_style_set_line_width(&minor_ticks_style, 2U);    /*Tick width*/
    lv_obj_add_style(scale, &minor_ticks_style, LV_PART_ITEMS);
    static lv_style_t main_line_style;
    lv_style_init(&main_line_style);
    /* Main line properties */
    lv_style_set_line_color(&main_line_style, lv_palette_darken(LV_PALETTE_GREEN, 3));
    lv_style_set_line_width(&main_line_style, 2U); // Tick width
    lv_obj_add_style(scale, &main_line_style, LV_PART_MAIN);
    /* Add top section */
    static lv_style_t section_minor_tick_style;
    static lv_style_t section_label_style;
    static lv_style_t section_main_line_style;
    lv_style_init(&section_label_style);
    lv_style_init(&section_minor_tick_style);
    lv_style_init(&section_main_line_style);
    lv_style_set_text_font(&section_label_style, LV_FONT_DEFAULT);
    lv_style_set_text_color(&section_label_style, lv_palette_darken(LV_PALETTE_RED, 3));
    lv_style_set_line_color(&section_label_style, lv_palette_darken(LV_PALETTE_RED, 3));
    lv_style_set_line_width(&section_label_style, 2U); /*Tick width*/
    lv_style_set_line_color(&section_minor_tick_style, lv_palette_lighten(LV_PALETTE_RED, 2));
    lv_style_set_line_width(&section_minor_tick_style, 2U); /*Tick width*/
    lv_style_set_line_color(&section_main_line_style, lv_palette_darken(LV_PALETTE_RED, 3));
    lv_style_set_line_width(&section_main_line_style, 2U); /*Tick width*/
    /* Configure section styles */
    lv_scale_section_t * section = lv_scale_add_section(scale);
    lv_scale_section_set_range(section, 35, 50);
    lv_scale_section_set_style(section, LV_PART_INDICATOR, &section_label_style);
    lv_scale_section_set_style(section, LV_PART_ITEMS, &section_minor_tick_style);
    lv_scale_section_set_style(section, LV_PART_MAIN, &section_main_line_style);
    /* add bottom section */
    static lv_style_t section_minor_tick_style_b;
    static lv_style_t section_label_style_b;
    static lv_style_t section_main_line_style_b;
    lv_style_init(&section_label_style_b);
    lv_style_init(&section_minor_tick_style_b);
    lv_style_init(&section_main_line_style_b);
    lv_style_set_text_font(&section_label_style_b, LV_FONT_DEFAULT);
    lv_style_set_text_color(&section_label_style_b, lv_palette_darken(LV_PALETTE_BLUE, 3));
    lv_style_set_line_color(&section_label_style_b, lv_palette_darken(LV_PALETTE_BLUE, 3));
    lv_style_set_line_width(&section_label_style_b, 2U); /*Tick width*/
    lv_style_set_line_color(&section_minor_tick_style_b, lv_palette_lighten(LV_PALETTE_BLUE, 2));
    lv_style_set_line_width(&section_minor_tick_style_b, 2U); /*Tick width*/
    lv_style_set_line_color(&section_main_line_style_b, lv_palette_darken(LV_PALETTE_BLUE, 3));
    lv_style_set_line_width(&section_main_line_style_b, 2U); /*Tick width*/
    lv_scale_section_t * section_b = lv_scale_add_section(scale);
    lv_scale_section_set_range(section_b, 0, 10);
    lv_scale_section_set_style(section_b, LV_PART_INDICATOR, &section_label_style_b);
    lv_scale_section_set_style(section_b, LV_PART_ITEMS, &section_minor_tick_style_b);
    lv_scale_section_set_style(section_b, LV_PART_MAIN, &section_main_line_style_b);
    /*Create line style*/
    static lv_style_t style_needle;
    lv_style_init(&style_needle);
    lv_style_set_line_width(&style_needle, 8);
    lv_style_set_line_color(&style_needle, lv_palette_main(LV_PALETTE_BROWN));
    lv_style_set_line_rounded(&style_needle, true);
    needle_line = lv_line_create(scale);
    lv_obj_add_style(needle_line, &style_needle, 0);
    lv_obj_set_style_bg_color(scale, lv_palette_main(LV_PALETTE_BLUE_GREY), 0);
    lv_obj_set_style_bg_opa(scale, LV_OPA_50, 0);
    lv_obj_set_style_pad_left(scale, 8, 0);
    lv_obj_set_style_radius(scale, 8, 0);
    lv_obj_set_style_pad_ver(scale, 20, 0);
    /* animate the scale */
    lv_anim_t anim_scale_line;
    lv_anim_init(&anim_scale_line);
    lv_anim_set_var(&anim_scale_line, scale);
    lv_anim_set_exec_cb(&anim_scale_line, set_needle_line_value);
    lv_anim_set_duration(&anim_scale_line, 1000);
    lv_anim_set_repeat_count(&anim_scale_line, LV_ANIM_REPEAT_INFINITE);
    lv_anim_set_playback_duration(&anim_scale_line, 1000);
    lv_anim_set_values(&anim_scale_line, 5, 45);
    lv_anim_start(&anim_scale_line);
lv_indev_t * indev; //Touchscreen input device
uint8_t* draw_buf;  //draw_buf is allocated on heap otherwise the static area is too big on ESP32 at compile
uint32_t lastTick = 0;  //Used to track the tick timer
void setup()
  //Some basic info on the Serial console
  String LVGL_Arduino = "LVGL demo ";
  LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
  Serial.begin(115200);
  Serial.println(LVGL_Arduino);
  //Initialise the touchscreen
  touchscreenSpi.begin(XPT2046_CLK, XPT2046_MISO, XPT2046_MOSI, XPT2046_CS); /* Start second SPI bus for touchscreen */
  touchscreen.begin(touchscreenSpi); /* Touchscreen init */
  touchscreen.setRotation(3); /* Inverted landscape orientation to match screen */
  //Initialise LVGL
  draw_buf = new uint8_t[DRAW_BUF_SIZE];
  lv_display_t * disp;
  disp = lv_tft_espi_create(TFT_HOR_RES, TFT_VER_RES, draw_buf, DRAW_BUF_SIZE);
  //Initialize the XPT2046 input device driver
  indev = lv_indev_create();
  lv_indev_set_read_cb(indev, my_touchpad_read);
  //lv_create_main_gui();
  lv_example_scale_2();
void loop()
    lv_tick_inc(millis() - lastTick); //Update the tick timer. Tick is new for LVGL 9
    lastTick = millis();
    lv_timer_handler();               //Update the UI
    delay(5);
Youtube link: https://youtube.com/shorts/lIyYJz2Kyt0?feature=share
