How to display custom Unicode characters in dev-7
Hi,everyone.
I want to display custom Unicode characters in dev-7. But there seems to be something wrong. Custom Unicode characters cannot be displayed normally in dev-7.
Does anyone know how to solve it? thank you!
  • eclipse
  • Display Unicode and Chinese in dev7
  • I tried to display a character(unicode:\uf00c) in the built-in library directly in Unicode.
  • I try to display a character(unicode:\uf00c) in the built-in library directly with hex value.
  • This means there is no problem using the character or Unicode encoding directly.But when I use online font generation, characters(测试abcd℃●√×) cannot be displayed normally.
    Bpp: 4bit-per-pixel
    Symbols: 测试abcd℃●√×
    Enable font compression: no
    Horizontal subpixel hinting: no
main.c (6.7 KB)
my_font_CH.c (6.1 KB)
  • This is my code in main.
  	static lv_style_t style1;
  	static lv_style_t style2;
  	lv_style_init(&style1);
  	lv_style_init(&style2);
  	_lv_style_set_int(&style1, LV_STYLE_TEXT_LINE_SPACE, 5);
  	LV_FONT_DECLARE(my_font_CH);
  	//lv_style_copy(&style1, &LV_FONT_MONTSERRAT_20);
  	lv_obj_t * label1 = lv_label_create(lv_scr_act(), NULL);
  	lv_obj_t * label2 = lv_label_create(lv_scr_act(), NULL);
  	lv_style_set_text_font(&style1, LV_STATE_DEFAULT, &my_font_CH);
  	lv_style_set_text_font(&style2, LV_STATE_DEFAULT, &my_font_CH);
  	lv_obj_set_style_local_text_color(label1, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_RED);
  	lv_obj_set_style_local_text_color(label2, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_ORANGE);
  	lv_style_set_text_blend_mode(&style1, LV_STATE_DEFAULT, LV_BLEND_MODE_SUBTRACTIVE);
  	lv_label_set_text(label1, LV_SYMBOL_OK "a测试abcd℃●√×a\u6D4B");
  	char * xx="da√测试b℃●√c\uF00C";
  	lv_label_set_text(label2, xx);
  	/* Position the main label */
  	lv_obj_align(label1, NULL, LV_ALIGN_CENTER, 0, 0);
  	lv_obj_align(label2, NULL, LV_ALIGN_CENTER, 0, 12);
  • This is file my_font_CH.c.
#include "lvgl/lvgl.h"
 * Size: 12 px
 * Bpp: 4
 * Opts:
#ifndef MY_FONT_CH
#define MY_FONT_CH 1
#if MY_FONT_CH
 *    BITMAPS
/*Store the image of the glyphs*/
static LV_ATTRIBUTE_LARGE_CONST const uint8_t gylph_bitmap[] = {
    /* U+61 "a" */
    0x6, 0xa9, 0xb2, 0x1, 0xf0, 0x6, 0x90, 0x1,
    0x25, 0xaa, 0x1, 0xc6, 0x36, 0xa0, 0x79, 0x0,
    0x9a, 0x2, 0xcb, 0xa4, 0xc7,
    /* U+62 "b" */
    0x5d, 0x50, 0x0, 0x0, 0xa5, 0x0, 0x0, 0xa,
    0x50, 0x0, 0x0, 0xa9, 0x9c, 0xb1, 0xa, 0x70,
    0x9, 0x90, 0xa5, 0x0, 0x4d, 0xa, 0x50, 0x4,
    0xc0, 0xa8, 0x0, 0xb7, 0xa, 0x59, 0xc9, 0x0,
    /* U+63 "c" */
    0x4, 0xa9, 0xb3, 0x2e, 0x10, 0x3c, 0x6a, 0x0,
    0x0, 0x6b, 0x0, 0x0, 0x2e, 0x20, 0x6, 0x4,
    0xca, 0x92,
    /* U+64 "d" */
    0x0, 0x0, 0x2c, 0x10, 0x0, 0x0, 0x7f, 0x10,
    0x0, 0x0, 0xf, 0x10, 0x4, 0xca, 0x8f, 0x10,
    0x2e, 0x10, 0x2f, 0x10, 0x6b, 0x0, 0xf, 0x10,
    0x7a, 0x0, 0xf, 0x10, 0x2e, 0x0, 0x2f, 0x10,
    0x6, 0xb8, 0x6f, 0xa0,
    /* U+D7 "×" */
    0x10, 0x0, 0x0, 0x1, 0x6c, 0x0, 0x0, 0xa7,
    0x7, 0xb0, 0xa, 0x80, 0x0, 0x8b, 0x99, 0x0,
    0x0, 0xd, 0xe0, 0x0, 0x0, 0x9a, 0x9a, 0x0,
    0x8, 0xa0, 0x9, 0x90, 0x6a, 0x0, 0x0, 0xa8,
    /* U+2103 "℃" */
    0x25, 0x30, 0x6, 0x96, 0x40, 0x70, 0x71, 0xc4,
    0x4, 0xe2, 0x55, 0x5b, 0x60, 0x0, 0x55, 0x0,
    0x1f, 0x0, 0x0, 0x3, 0x0, 0x3e, 0x0, 0x0,
    0x0, 0x0, 0x3f, 0x0, 0x0, 0x0, 0x0, 0xe,
    0x40, 0x0, 0x2, 0x0, 0x6, 0xd1, 0x0, 0x75,
    0x0, 0x0, 0x5d, 0xcb, 0x50,
    /* U+221A "√" */
    0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0,
    0x0, 0x0, 0x0, 0x9, 0x0, 0x0, 0x0, 0x0,
    0x0, 0x56, 0x0, 0x0, 0x0, 0x0, 0x2, 0xa0,
    0x0, 0x0, 0x0, 0x0, 0xb, 0x10, 0x2, 0x72,
    0x0, 0x0, 0x93, 0x0, 0x16, 0x8b, 0x0, 0x5,
    0x70, 0x0, 0x0, 0xe, 0x30, 0x1a, 0x0, 0x0,
    0x0, 0x6, 0xc0, 0xa1, 0x0, 0x0, 0x0, 0x0,
    0xdc, 0x40, 0x0, 0x0, 0x0, 0x0, 0x58, 0x0,
    /* U+25CF "●" */
    0x0, 0x18, 0xbb, 0x82, 0x0, 0x5, 0xff, 0xff,
    0xff, 0x50, 0x2f, 0xff, 0xff, 0xff, 0xf2, 0xaf,
    0xff, 0xff, 0xff, 0xfa, 0xef, 0xff, 0xff, 0xff,
    0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0xff,
    0xff, 0xff, 0xfc, 0x5f, 0xff, 0xff, 0xff, 0xf5,
    0xa, 0xff, 0xff, 0xff, 0xa0, 0x0, 0x6e, 0xff,
    0xe7, 0x0, 0x0, 0x0, 0x11, 0x0, 0x0,
    /* U+6D4B "测" */
    0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x5, 0x50,
    0x20, 0x31, 0x1, 0xd0, 0x0, 0xd3, 0xd6, 0xd6,
    0x11, 0xd0, 0x0, 0x13, 0xc7, 0xd1, 0xb2, 0xd0,
    0x3b, 0x15, 0xcb, 0xc1, 0xb1, 0xd0, 0x9, 0x71,
    0xcb, 0xc1, 0xb1, 0xd0, 0x0, 0x70, 0xcb, 0xc1,
    0xb1, 0xd0, 0x1, 0x70, 0xcb, 0xc1, 0xb1, 0xd0,
    0x2d, 0x50, 0x9c, 0x80, 0xa1, 0xd0, 0x9, 0x40,
    0x47, 0xd4, 0x1, 0xd0, 0xc, 0x51, 0x80, 0x8d,
    0x57, 0xd0, 0x9, 0x76, 0x0, 0x3, 0xd, 0x60,
    /* U+8BD5 "试" */
    0x0, 0x0, 0x0, 0x1, 0x0, 0x0, 0x2, 0xa2,
    0x0, 0xc, 0x77, 0x0, 0x0, 0x89, 0x0, 0xb,
    0x3a, 0x30, 0x0, 0x23, 0x55, 0x5c, 0x75, 0xc3,
    0x23, 0xa2, 0x0, 0x9, 0x50, 0x0, 0x12, 0xe2,
    0x67, 0xbd, 0x70, 0x0, 0x0, 0xe1, 0xd, 0x15,
    0xa0, 0x0, 0x0, 0xe1, 0xd, 0x12, 0xd0, 0x0,
    0x0, 0xe4, 0x3d, 0x34, 0xe3, 0x14, 0x0, 0xf9,
    0x8e, 0x81, 0x7c, 0x62, 0x2, 0xd0, 0x81, 0x0,
    0xd, 0xf1, 0x0, 0x10, 0x0, 0x0, 0x2, 0xc4
 *  GLYPH DESCRIPTION
static const lv_font_fmt_txt_glyph_dsc_t glyph_dsc[] = {
    {.bitmap_index = 0, .adv_w = 0, .box_w = 0, .box_h = 0, .ofs_x = 0, .ofs_y = 0} /* id = 0 reserved */,
    {.bitmap_index = 0, .adv_w = 111, .box_w = 7, .box_h = 6, .ofs_x = 0, .ofs_y = 0},
    {.bitmap_index = 21, .adv_w = 119, .box_w = 7, .box_h = 9, .ofs_x = 0, .ofs_y = 0},
    {.bitmap_index = 53, .adv_w = 100, .box_w = 6, .box_h = 6, .ofs_x = 0, .ofs_y = 0},
    {.bitmap_index = 71, .adv_w = 119, .box_w = 8, .box_h = 9, .ofs_x = 0, .ofs_y = 0},
    {.bitmap_index = 107, .adv_w = 192, .box_w = 8, .box_h = 9, .ofs_x = 2, .ofs_y = -1},
    {.bitmap_index = 143, .adv_w = 192, .box_w = 10, .box_h = 9, .ofs_x = 1, .ofs_y = 0},
    {.bitmap_index = 188, .adv_w = 192, .box_w = 12, .box_h = 12, .ofs_x = 0, .ofs_y = -2},
    {.bitmap_index = 260, .adv_w = 192, .box_w = 10, .box_h = 11, .ofs_x = 1, .ofs_y = -2},
    {.bitmap_index = 315, .adv_w = 192, .box_w = 12, .box_h = 13, .ofs_x = 0, .ofs_y = -3},
    {.bitmap_index = 393, .adv_w = 192, .box_w = 12, .box_h = 12, .ofs_x = 0, .ofs_y = -2}
 *  CHARACTER MAPPING
static const uint16_t unicode_list_0[] = {
    0x0, 0x1, 0x2, 0x3, 0x76, 0x20a2, 0x21b9, 0x256e,
    0x6cea, 0x8b74
/*Collect the unicode lists and glyph_id offsets*/
static const lv_font_fmt_txt_cmap_t cmaps[] =
        .range_start = 97, .range_length = 35701, .glyph_id_start = 1,
        .unicode_list = unicode_list_0, .glyph_id_ofs_list = NULL, .list_length = 10, .type = LV_FONT_FMT_TXT_CMAP_SPARSE_TINY
 *  ALL CUSTOM DATA
/*Store all the custom data of the font*/
static lv_font_fmt_txt_dsc_t font_dsc = {
    .glyph_bitmap = gylph_bitmap,
    .glyph_dsc = glyph_dsc,
    .cmaps = cmaps,
    .kern_dsc = NULL,
    .kern_scale = 0,
    .cmap_num = 1,
    .bpp = 4,
    .kern_classes = 0,
    .bitmap_format = 0
 *  PUBLIC FONT
/*Initialize a public general font descriptor*/
lv_font_t my_font_CH = {
    .get_glyph_dsc = lv_font_get_glyph_dsc_fmt_txt,    /*Function pointer to get glyph's data*/
    .get_glyph_bitmap = lv_font_get_bitmap_fmt_txt,    /*Function pointer to get glyph's bitmap*/
    .line_height = 13,          /*The maximum line height required by the font*/
    .base_line = 3,             /*Baseline measured from the bottom of the line*/
#if !(LVGL_VERSION_MAJOR == 6 && LVGL_VERSION_MINOR == 0)
    .subpx = LV_FONT_SUBPX_NONE,
    .dsc = &font_dsc           /*The custom font data. Will be accessed by `get_glyph_bitmap/dsc` */
#endif /*#if MY_FONT_CH*/
OT: Don’t do that; use lv_style_set_text_line_space instead. It’s there for a reason. :slightly_smiling_face:
It seems that you didn’t add the style to the label, and thus it’s not using your font? (Use lv_obj_add_style.)
Thank you.:grinning:
I just tried.
  • The style was not added to the label.
  • There are still some problems. Some characters are not shown.
  • characters “测试√℃●” only shown “试”, “测√℃●” has been lost.I’m sure the font can display these characters normally, and it has been converted correctly.
  • Maybe it’s a bug?
    This is the code in main.
 lv_obj_add_style(label1, LV_OBJ_PART_MAIN, &style1);
 lv_obj_add_style(label2, LV_OBJ_PART_MAIN, &style2);
 lv_label_set_text(label1, "测试√℃●");
 char * xx="\u6D4B 试测测测测 试da√测试b℃●√c\uF00C";
I think it’s a bug.I’ll report it.
Thanks for @as564335sa ’s answer,now everything is ok. Some custom Unicode characters can not be displayed in dev-7
1
Hello
According to your solution,mine still cannot display Chinese.
Using your Chinese font can not be displayed.Everything else can be displayed normally
Can you help me?
Do you use the latest version form master?
Try to use the built-in LV_FONT_SIMSUN_16_CJK font.
Thank you very much。That problem has been solved,I rebuilt the problem I had encountered。The related solution code is already written under the problem。
