How to display a chart that uses floating values?
I’m following the widgets_demo from lvgl_demos project. I need to display a chart that can show floating point values.
Currently it seems the chart widget only takes integer values. As presented in the following image:
Is there a way I can use the chart for floating-point values or do I have to modify the existing widget?
Thanks.
PS: Storage, ram and cpu cycles are of no concern. The program will run on a rpi.
Hi @_nullguy ,
See this post for an example.
Kind Regards,
Pete
Much appreciated. Thanks for your work.
