V8.3.9, vs simulator[800x480]
disable the focus border.
I create a roller widget and set the border to 0, but a border still have been show when i run the simulator.
use border set api:
lv_obj_set_style_border_width(roller1, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
/* create a black backgroud */
lv_obj_t* bg= lv_obj_create(lv_scr_act());
lv_obj_remove_style_all(bg);
lv_obj_set_pos(bg, 0, 0);
lv_obj_set_size(bg, UI_SIZE_WIDTH, UI_SIZE_HEIGHT);
lv_obj_set_style_bg_color(bg, lv_color_hex(0x000000), 0);
lv_obj_set_style_bg_opa(bg, 255, 0);
/*create string for the roller*/
static char buff[1024];
char* p;
int len;
buff[0] = '\0';
p = buff;
for (int i = 1; i < 10; i++)
len = sprintf(p, "%02d\n", i);
p += len;
*(p - 1) = '\0';
/* create a roller widget */
lv_obj_t* roller1 = lv_roller_create(bg);
lv_roller_set_options(roller1,
buff,
LV_ROLLER_MODE_INFINITE);
lv_obj_set_width(roller1, 175);
lv_obj_set_pos(roller1, 180,130);
/* set roller font */
#if LV_FONT_MONTSERRAT_42
lv_obj_set_style_text_font(roller1, &lv_font_montserrat_42, LV_PART_SELECTED);
#if LV_FONT_MONTSERRAT_32
lv_obj_set_style_text_font(roller1, &lv_font_montserrat_32, LV_PART_MAIN);
/*you should set the height after the the text font*/
lv_obj_set_style_text_line_space(roller1, 32, 0);
lv_roller_set_visible_row_count(roller1, 5);
lv_obj_set_style_pad_all(roller1, 0, LV_PART_MAIN);
lv_obj_set_style_radius(roller1, 0, LV_PART_MAIN);
lv_obj_set_style_bg_opa(roller1, LV_OPA_TRANSP, LV_PART_MAIN);
lv_obj_set_style_bg_opa(roller1, LV_OPA_30, LV_PART_SELECTED);
lv_obj_set_style_bg_color(roller1, lv_color_make(0, 0, 0), LV_PART_SELECTED);
lv_obj_set_style_text_color(roller1, lv_color_make(100, 100, 100), LV_PART_MAIN);
lv_obj_set_style_text_color(roller1, lv_color_make(255, 255, 255), LV_PART_SELECTED);
lv_obj_set_style_anim_speed(roller1, 1000, 0);
lv_obj_t* temp = lv_btn_create(bg);
lv_obj_set_size(temp, 50, 50);
lv_obj_set_pos(temp, 675, 10);
lv_obj_add_event_cb(temp, roller_btn_cb, LV_EVENT_CLICKED, NULL);
Screenshot
if Slide the mouse wheel , this border would go to the btn, like follows.
Can you kindly give me some advices about this issue?
