How to disable the cursor on textarea
I want to disable the cursor on textarea when it is in LV_STATE_DISABLED state. but I found no way to do directly. Is there any way to solve it ?
V9.1.1
disable the cursor on textarea when the textarea is disable
using lv_obj_set_style_anim_time api to set the time to 0, but when the textarea is focused, the cursor is still existed ( but not blinking)
static void cb_event_cb(lv_event_t* e)
    lv_obj_t* ta = static_cast<lv_obj_t*>(lv_event_get_user_data(e));
    lv_obj_t* obj = static_cast<lv_obj_t*>(lv_event_get_target(e));
    if (code == LV_EVENT_VALUE_CHANGED)
        if (!(lv_obj_get_state(obj) & LV_STATE_CHECKED))
            lv_obj_add_state(ta, LV_STATE_DISABLED);
            lv_obj_remove_state(ta, LV_STATE_DISABLED);
static void ta_event_cb(lv_event_t* e)
    lv_obj_t* ta = static_cast<lv_obj_t*>(lv_event_get_target(e));
    lv_obj_t* kb = static_cast<lv_obj_t*>(lv_event_get_user_data(e));
    if (code == LV_EVENT_FOCUSED) {
        if (lv_indev_get_type(lv_indev_active()) != LV_INDEV_TYPE_KEYPAD && !(lv_obj_get_state(ta) & LV_STATE_DISABLED)) {
            lv_keyboard_set_textarea(kb, ta);
            lv_obj_set_style_max_height(kb, LV_HOR_RES * 1 / 3, 0);
            lv_obj_set_style_max_width(kb, LV_VER_RES * 2 / 3, 0);
            //lv_obj_update_layout(tv);   /*Be sure the sizes are recalculated*/
            //lv_obj_set_height(tv, LV_VER_RES - lv_obj_get_height(kb));
            lv_obj_remove_flag(kb, LV_OBJ_FLAG_HIDDEN);
            lv_obj_scroll_to_view_recursive(ta, LV_ANIM_OFF);
            lv_indev_wait_release(static_cast<lv_indev_t*>(lv_event_get_param(e)));
        else if (lv_obj_get_state(ta) & LV_STATE_DISABLED)
            lv_obj_set_style_anim_time(ta, 0, LV_PART_CURSOR | LV_STATE_FOCUSED);
    else if (code == LV_EVENT_DEFOCUSED) {
        lv_keyboard_set_textarea(kb, NULL);
        //lv_obj_set_height(tv, LV_VER_RES);
        lv_obj_add_flag(kb, LV_OBJ_FLAG_HIDDEN);
        lv_indev_reset(NULL, ta);
    else if (code == LV_EVENT_READY || code == LV_EVENT_CANCEL) {
        lv_indev_reset(NULL, ta);   /*To forget the last clicked object to make it focusable again*/
    else if (code == LV_EVENT_REFR_EXT_DRAW_SIZE)
        lv_event_set_ext_draw_size(e, 100);
void create_single_network_config(lv_obj_t* parent,const char* title)
    lv_obj_t* title_lab = lv_label_create(parent);
    lv_obj_t* ip_txt = lv_textarea_create(parent);
    lv_obj_t* submask_txt = lv_textarea_create(parent);
    lv_obj_t* gateway_txt = lv_textarea_create(parent);
    lv_obj_t* ip_lab = lv_label_create(ip_txt);
    lv_obj_t* submask_lab = lv_label_create(submask_txt);
    lv_obj_t* gateway_lab = lv_label_create(gateway_txt);
    lv_obj_t* enable = lv_checkbox_create(parent);
    lv_obj_t*  kb = lv_keyboard_create(lv_screen_active());
    lv_obj_set_size(kb, LV_HOR_RES, LV_VER_RES / 2);
    lv_keyboard_set_mode(kb, LV_KEYBOARD_MODE_NUMBER);
    lv_label_set_text(title_lab, title);
    lv_label_set_text(ip_lab, "Ip Address");
    lv_label_set_text(submask_lab, "SubMask");
    lv_label_set_text(gateway_lab, "GateWay");
    lv_checkbox_set_text(enable, "Enable");
    lv_obj_add_flag(ip_txt, LV_OBJ_FLAG_OVERFLOW_VISIBLE);
    lv_obj_add_flag(submask_txt, LV_OBJ_FLAG_OVERFLOW_VISIBLE);
    lv_obj_add_flag(gateway_txt, LV_OBJ_FLAG_OVERFLOW_VISIBLE);
    lv_obj_align_to(ip_lab, ip_txt, LV_ALIGN_OUT_TOP_LEFT,0,-5);
    lv_obj_align_to(submask_lab, submask_txt, LV_ALIGN_OUT_TOP_LEFT,0,-5);
    lv_obj_align_to(gateway_lab, gateway_txt, LV_ALIGN_OUT_TOP_LEFT,0,-5);
    lv_obj_add_state(ip_txt, LV_STATE_DISABLED);
  /*  lv_obj_add_state(submask_txt, LV_STATE_DISABLED);
    lv_obj_add_state(gateway_txt, LV_STATE_DISABLED);*/
    lv_obj_set_width(ip_txt, lv_pct(100));
    lv_obj_set_width(submask_txt, lv_pct(100));
    lv_obj_set_width(gateway_txt, lv_pct(100));
    lv_obj_set_height(ip_txt, lv_pct(10));
    lv_obj_set_height(submask_txt, lv_pct(10));
    lv_obj_set_height(gateway_txt, lv_pct(10));
    lv_obj_set_style_text_font(title_lab, &lv_font_montserrat_32, 0);
    lv_obj_add_event_cb(ip_txt, ta_event_cb, LV_EVENT_ALL, kb);
    lv_obj_add_event_cb(submask_txt, ta_event_cb, LV_EVENT_ALL, kb);
    lv_obj_add_event_cb(gateway_txt, ta_event_cb, LV_EVENT_ALL, kb);
    lv_obj_add_event_cb(enable, cb_event_cb, LV_EVENT_ALL, ip_txt);
    lv_obj_set_grid_dsc_array(parent, network_col_dsc, network_row_dsc);
    lv_obj_set_grid_cell(title_lab, LV_GRID_ALIGN_START, 0, 1, LV_GRID_ALIGN_STRETCH, 0, 1);
    lv_obj_set_grid_cell(ip_txt, LV_GRID_ALIGN_START, 0, 1, LV_GRID_ALIGN_START, 1, 1);
    lv_obj_set_grid_cell(submask_txt, LV_GRID_ALIGN_START, 0, 1, LV_GRID_ALIGN_START, 2, 1);
    lv_obj_set_grid_cell(gateway_txt, LV_GRID_ALIGN_START, 0, 1, LV_GRID_ALIGN_START, 3, 1);
    lv_obj_set_grid_cell(enable, LV_GRID_ALIGN_START, 0, 1, LV_GRID_ALIGN_START, 4, 1);
void create_network_config(int num,lv_obj_t* parent)
    lv_obj_t* tabview = lv_tabview_create(parent);
    lv_tabview_set_tab_bar_position(tabview, LV_DIR_LEFT);
    lv_tabview_set_tab_bar_size(tabview, 80);
    for (int i = 0; i < num; i++)
        char tab_cont[32] = { 0 };
        sprintf(tab_cont, "Ethernet%d", i+1);
        lv_obj_t* tab = lv_tabview_add_tab(tabview, tab_cont);
        create_single_network_config(tab, tab_cont);
int main()
     * Optional workaround for users who wants UTF-8 console output.
     * If you don't want that behavior can comment them out.
     * Suggested by jinsc123654.
#if LV_TXT_ENC == LV_TXT_ENC_UTF8
    SetConsoleCP(CP_UTF8);
    SetConsoleOutputCP(CP_UTF8);
    int32_t zoom_level = 100;
    bool allow_dpi_override = false;
    bool simulator_mode = true;
    lv_display_t* display = lv_windows_create_display(
        L"LVGL Windows Simulator Display 1",
        800,
        480,
        zoom_level,
        allow_dpi_override,
        simulator_mode);
    if (!display)
        return -1;
    HWND window_handle = lv_windows_get_display_window_handle(display);
    if (!window_handle)
        return -1;
    HICON icon_handle = LoadIconW(
        GetModuleHandleW(NULL),
        MAKEINTRESOURCE(IDI_LVGL_WINDOWS));
    if (icon_handle)
        SendMessageW(
            window_handle,
            WM_SETICON,
            TRUE,
            (LPARAM)icon_handle);
        SendMessageW(
            window_handle,
            WM_SETICON,
            FALSE,
    lv_indev_t* pointer_indev = lv_windows_acquire_pointer_indev(display);
    if (!pointer_indev)
        return -1;
    lv_indev_t* keypad_indev = lv_windows_acquire_keypad_indev(display);
    if (!keypad_indev)
        return -1;
    lv_indev_t* encoder_indev = lv_windows_acquire_encoder_indev(display);
    if (!encoder_indev)
        return -1;
    lv_obj_t* window1 = lv_obj_create(lv_screen_active());
    lv_obj_t* panel1 = lv_obj_create(window1);
    lv_obj_t* panel2 = lv_obj_create(window1);
    lv_obj_t* title = lv_label_create(panel1);
    lv_obj_t* back_btn = lv_button_create(panel1);
    lv_obj_t* back_btn_label = lv_label_create(back_btn);
    lv_obj_t* next_btn = lv_button_create(panel1);
    lv_obj_t* next_btn_label = lv_label_create(next_btn);
    lv_label_set_text(title, "Configure Network");
    lv_label_set_text(back_btn_label, "< Cancel");
    lv_label_set_text(next_btn_label, "Apply >");
    lv_obj_align(title, LV_ALIGN_CENTER, 0, 0);
    lv_obj_align(back_btn, LV_ALIGN_BOTTOM_LEFT, 0, 0);
    lv_obj_align(next_btn, LV_ALIGN_BOTTOM_RIGHT, 0, 0);
    lv_obj_set_size(window1, lv_pct(100), lv_pct(100));
    //lv_obj_set_flex_flow(panel2, LV_FLEX_FLOW_COLUMN);
    create_network_config(4, panel2);
    static lv_style_t style_label_title,style_label_back,style_label_right;
    lv_style_init(&style_label_title);
    lv_style_init(&style_label_back);
    lv_style_init(&style_label_right);
    lv_obj_set_style_bg_color(panel1, lv_palette_main(LV_PALETTE_GREY), 0);
    lv_obj_set_style_bg_color(back_btn, lv_palette_main(LV_PALETTE_GREY), 0);
    lv_obj_set_style_bg_color(next_btn, lv_palette_main(LV_PALETTE_GREY), 0);
    //lv_obj_set_style_bg_color(panel2, lv_color_black(), 0);
    //lv_obj_set_style_bg_color(window1, lv_color_black(), 0);
    lv_obj_set_style_radius(window1, 0, 0);
    lv_obj_set_style_radius(panel1, 0, 0);
    lv_obj_set_style_radius(panel2, 0, 0);
    lv_obj_set_style_pad_all(window1, 0, 0);
    lv_obj_set_style_pad_all(panel1, 0, 0);
    lv_obj_set_style_pad_all(panel2, 0, 0);
    lv_obj_set_style_pad_row(window1, 0, 0);
    lv_obj_set_style_pad_column(window1, 0, 0);
    lv_obj_set_style_border_width(panel1, 0, 0);
    lv_obj_set_style_border_width(panel2, 0, 0);
    lv_style_set_text_color(&style_label_title, lv_color_hex(0xFFFFFF));
    lv_style_set_text_color(&style_label_back, lv_palette_main(LV_PALETTE_BLUE));
    lv_style_set_text_color(&style_label_right, lv_palette_main(LV_PALETTE_BLUE));
    lv_obj_add_style(title, &style_label_title, 0);
    lv_obj_add_style(back_btn_label, &style_label_back, 0);
    lv_obj_add_style(next_btn_label, &style_label_right, 0);
    lv_obj_set_flex_align(panel2, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
    lv_obj_set_grid_dsc_array(window1, col_dsc, row_dsc);
    lv_obj_set_grid_cell(panel1, LV_GRID_ALIGN_STRETCH, 0, 1, LV_GRID_ALIGN_STRETCH, 0, 1);
    lv_obj_set_grid_cell(panel2, LV_GRID_ALIGN_STRETCH, 0, 1, LV_GRID_ALIGN_STRETCH, 1, 1);
    while (1)
        uint32_t time_till_next = lv_timer_handler();
        lv_delay_ms(time_till_next);
    return 0;
I don’t know if this can help you.
I use a function that disable cursor on a text input label.
 * @brief Custom LVGL function to hide cursor
 * @param LVGL object
void objHideCursor(_lv_obj_t *obj)
  static lv_style_t style1;
  lv_style_init(&style1);
  lv_style_set_bg_opa(&style1, LV_OPA_TRANSP);
  lv_style_set_text_opa(&style1, LV_OPA_TRANSP);
  lv_obj_add_style(obj, &style1, LV_PART_CURSOR);
  static lv_style_t style2;
  lv_style_init(&style2);
  lv_style_set_bg_opa(&style2, LV_OPA_100);
  lv_style_set_text_opa(&style2, LV_OPA_100);
  lv_obj_add_style(obj, &style2, LV_PART_CURSOR | LV_STATE_FOCUS_KEY);
  lv_obj_add_style(obj, &style2, LV_PART_CURSOR | LV_STATE_FOCUSED);
Thank you for your reply. But I found this function didn’t work for the textarea… :frowning:
Ops, sorry
Function static start_cursor_blink() inside lv_textarea.c,is responsible for displaying the cursor.
For the test, do:
static void start_cursor_blink(lv_obj_t * obj)
return;
Thanks a lot!!
