Hi, I’m developing an application with 2 screens, and about 5 lv_tasks on each screen. How can I pause/disable these tasks on screen that isn’t showing?
Stm32F4 with HAL and Keil
lvgl V7
Pause/disable tasks on determinate screen
Thanks
Hi @Marcelocm1995,
For version 7 take a look at the docs here.
When you create the tasks be sure to save the pointer returned by the task_create() function in a static or global variable so you can gain access to the task later.
Use the void lv_task_set_prio(lv_task_t *task, lv_task_prio_t prio) function to set a value of LV_TASK_PRIO_OFF to suspend the tasks and when you want to restart the tasks set the original priority again.
Example code:
static lv_task_t *task1_ptr;
static lv_task_t *task2_ptr;
void create_tasks( void ) {
task1_ptr = lv_task_t*lv_task_create( task1_cb, 100, LV_TASK_PRIO_MID, NULL);
task2_ptr = lv_task_t*lv_task_create( task2_cb, 200, LV_TASK_PRIO_LOW, NULL);
void suspend_tasks( void ) {
lv_task_set_prio( task1_ptr, LV_TASK_PRIO_OFF) ;
lv_task_set_prio( task2_ptr, LV_TASK_PRIO_OFF) ;
void restart_tasks( void ) {
lv_task_set_prio( task1_ptr, LV_TASK_PRIO_MID) ;
lv_task_set_prio( task2_ptr, LV_TASK_PRIO_LOW) ;
Hope that helps.
Kind Regards,
Pete
