we can use lv_obj_set_click() to set btns unclick, but I found it doesn’t work when object is ddlist or textarea. I want to set ddlist can’t open when I touch it.
For lv_ddlist, if you want to use lv_obj_set_click(ddlist, false)
add the following code to your code.
static lv_signal_cb_t anc_ddlist_scrl_signal;
static lv_res_t ddlist_ext_scrl_signal(lv_obj_t * scrl, lv_signal_t sign, void * param);
lv_obj_t* my_ddlist_create(lv_obj_t* par, lv_obj_t* copy) {
lv_obj_t* ddlist = lv_ddlist_create(par, copy);
lv_obj_t* ddlist_scrl = lv_page_get_scrl(ddlist);
anc_ddlist_scrl_signal = lv_obj_get_signal_cb(ddlist_scrl);
lv_obj_set_signal_cb(ddlist_scrl, ddlist_ext_scrl_signal);
return ddlist;
lv_res_t res = LV_RES_OK;
if ( sign != LV_SIGNAL_RELEASED || (sign == LV_SIGNAL_RELEASED && lv_obj_get_click(lv_obj_get_parent(scrl)) ) ) {
res = anc_ddlist_scrl_signal(scrl, sign, param);
return res;
Usage
void lv_example_ddlist(void)
/*Create a drop down list*/
lv_obj_t * ddlist = my_ddlist_create(lv_scr_act(), NULL);
lv_ddlist_set_options(ddlist, "Apple\n"
"Banana\n"
"Orange\n"
"Melon\n"
"Grape\n"
"Raspberry");
lv_ddlist_set_fix_width(ddlist, 150);
lv_ddlist_set_draw_arrow(ddlist, true);
lv_obj_align(ddlist, NULL, LV_ALIGN_IN_TOP_MID, 0, 20);
lv_obj_set_click(ddlist, false); // ---> disable click for ddlist
Fot lv_ta use the following code.
static lv_signal_cb_t anc_ta_scrl_signal;
static lv_res_t ta_ext_scrl_signal(lv_obj_t * scrl, lv_signal_t sign, void * param);
lv_obj_t* my_ta_create(lv_obj_t* par, lv_obj_t* copy) {
lv_obj_t* ta = lv_ta_create(par, copy);
lv_obj_t* ta_scrl = lv_page_get_scrl(ta);
anc_ta_scrl_signal = lv_obj_get_signal_cb(ta_scrl);
lv_obj_set_signal_cb(ta_scrl, ta_ext_scrl_signal);
return ta;
if(sign == LV_SIGNAL_PRESSING || sign == LV_SIGNAL_PRESSED || sign == LV_SIGNAL_PRESS_LOST ||
sign == LV_SIGNAL_RELEASED)
if(lv_obj_get_click(lv_obj_get_parent(scrl)))
res = anc_ta_scrl_signal(scrl, sign, param);
}else{
return res;
Usage
void lv_example_ta(void)
lv_obj_t* ta1 = my_ta_create(lv_scr_act(), NULL);
lv_obj_set_size(ta1, 200, 100);
lv_obj_align(ta1, NULL, LV_ALIGN_CENTER, 0, 0);
lv_ta_set_cursor_type(ta1, LV_CURSOR_BLOCK);
lv_ta_set_text(ta1, "A text in a Text Area"); /*Set an initial text*/
lv_obj_set_click(ta1, false); // ---> disable click for textarea
Are you using the latest version of LittlevGL? lv_ddlist should work with lv_obj_set_click; this was fixed here .
Can you explain how it work? It confused me.
zhangjiawei1992:
my version is 6.0.1,
That explains why it’s not working. You’ll have to either update to 6.1, backport this patch , or use @TridentTD ’s fix if you want the feature.
