LVGL version 7.11 in simulator.
Here I have a list of dynamically formed labels and associated check boxes for each to enable or disable. In a callback function I am using Y position on the screen of a check box to determine which one is clicked. It is kind a primitive solution. If anyone would suggest other way to accomplish this task I would appreciate it. This code is working as desired, I am just looking for alternative solution.
/* List of visible sensors */
lv_coord_t Y_POS = 60;
for (int i = 0; i < sizeof(sensors)/sizeof(sensors[0]); i++) {
#if EVENTS_DEBUG
printf("%s\n", sensors[i].name);
lv_obj_t * lbl_sen = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(lbl_sen, sensors[i].name);
lv_obj_add_style(lbl_sen, LV_BTN_PART_MAIN, &style_lbl_dt);
lv_obj_align(lbl_sen, NULL, LV_ALIGN_IN_TOP_LEFT, 20, Y_POS);
lv_obj_t * cbx_sen = lv_checkbox_create(lv_scr_act(), NULL);
lv_checkbox_set_text(cbx_sen, "");
lv_obj_align(cbx_sen, NULL, LV_ALIGN_IN_TOP_LEFT, 120, Y_POS);
lv_obj_set_event_cb(cbx_sen, cbx_sensors_event_handler);
Y_POS += 30;
/* Callback function */
void cbx_sensors_event_handler(lv_obj_t * obj, lv_event_t event)
if (event == LV_EVENT_VALUE_CHANGED) {
lv_coord_t y = lv_obj_get_y(obj); // Y_POS: 60, 90, 120, etc...
int sn = (y - 60) / 30;
#if EVENTS_DEBUG
printf("%d\n", y);
printf("Sensor %d. state is %s\n", sn + 1, lv_checkbox_is_checked(obj) ? "On" : "Off");
if (lv_checkbox_is_checked(obj)) {
#if EVENTS_DEBUG
printf("Sensor %d. readings enabled.\n", sn + 1);
else {
#if EVENTS_DEBUG
printf("Sensor %d. readings disabled.\n", sn + 1);
