lvgl simulator
Keyboard entry
int main()
int ch;
while (1)
if (_kbhit())//If a key is pressed, the ﹐ kbhit() function returns true
ch = _getch(); //Use the function ﹐ getch() to get the key value pressed
std::cout << ch << std::endl;
if (ch == 27)
break;
Sleep(10); /*Just to let the system breath*/
system:windows 10 1909
compiler:msvc+clang
I just want to check the input of the keyboard and finish the interface switching. I read ‘lv_drives/keyboard.h’. But I didn’t understand it. I hope I can provide a demo.thank you.
int main(int argc, char **argv)
/*Initialize LittlevGL*/
/*Initialize the HAL (display, input devices, tick) for LittlevGL*/
hal_init();
//lv_group_t *g = lv_group_create();
/* Add your objects to the group */
lv_indev_drv_t real_kb_drv;
keyboard_init();
real_kb_drv.type = LV_INDEV_TYPE_KEYPAD;
real_kb_drv.read_cb = keyboard_read;
lv_indev_data_t kbDate;
while (1)
std::cout << " is pressed?" << keyboard_read(&real_kb_drv, &kbDate) << " ";
std::cout << "value: " << kbDate.key << std::endl;
is pressed?0 value: 51
is pressed?0 value: 52
This is valid. It just doesn’t check whether the keyboard is pressed or not.
But it’s not a big problem,It can also be realized with nowkeyval and lastkeyval variables
You shouldn’t call the keyboard_read function directly. It’s designed to be registered as a standard LittlevGL keypad driver, so that you can interact with it using standard keypad events or signals.
Tested by me _getch(); It is invalid.
Therefore, you must use the function in lv_driver ->keyboard.h-> bool keyboard_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)to read the data.
I don’t know if it’s my msvc2019 + clang reason
