I have followed the example in the modal msgbox, but when I delete the screen directly, there is a segmentation fault
Simulator in CodeBlocks v7-dev
I would like to be able to delete the a screen in which a modal msgbox has been created an is active
I have copied the example msgbox_2, in which a modal msgbox is created, and then modified it so after activating the modal msgbox a new screen is created, loaded, and the previous is deleted. Then the program asserts a segmentation fault.
I think that the problem is with the lv_obj_del_async, which tries to delete the page in which the msgbox is created. When the msgbox is deleted, then the msgbox delete event deletes the page, but when the screen is deleted, I think that the page is deleted first, and then the delayed deleted is failing. That’s my assumption, but I don’t know a way to overcome this problem.
void lv_ex_msgbox_2(void)
lv_style_init(&style_modal);
lv_style_set_bg_color(&style_modal, LV_STATE_DEFAULT, LV_COLOR_BLACK);
/* Create a button, then set its position and event callback */
lv_obj_t *btn = lv_btn_create(lv_scr_act(), NULL);
lv_obj_set_size(btn, 200, 60);
lv_obj_set_event_cb(btn, btn_event_cb);
lv_obj_align(btn, NULL, LV_ALIGN_IN_TOP_LEFT, 20, 20);
/* Create a label on the button */
lv_obj_t *label = lv_label_create(btn, NULL);
lv_label_set_text(label, "Display a message box!");
/* Create an informative label on the screen */
info = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(info, welcome_info);
lv_label_set_long_mode(info, LV_LABEL_LONG_BREAK); /* Make sure text will wrap */
lv_obj_set_width(info, LV_HOR_RES - 10);
lv_obj_align(info, NULL, LV_ALIGN_IN_BOTTOM_LEFT, 5, -5);
/* Create a base object for the modal background */
lv_obj_t *obj = lv_obj_create(lv_scr_act(), NULL);
lv_obj_reset_style_list(obj, LV_OBJ_PART_MAIN);
lv_obj_add_style(obj, LV_OBJ_PART_MAIN, &style_modal);
lv_obj_set_pos(obj, 0, 0);
lv_obj_set_size(obj, LV_HOR_RES, LV_VER_RES);
static const char * btns2[] = {"Ok", "Cancel", ""};
/* Create the message box as a child of the modal background */
mbox = lv_msgbox_create(obj, NULL);
lv_msgbox_add_btns(mbox, btns2);
lv_msgbox_set_text(mbox, "Hello world!");
lv_obj_align(mbox, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_event_cb(mbox, mbox_event_cb);
/* Fade the message box in with an animation */
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_var(&a, obj);
lv_anim_set_time(&a, 500);
lv_anim_set_values(&a, LV_OPA_TRANSP, LV_OPA_50);
lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)opa_anim);
lv_anim_start(&a);
lv_label_set_text(info, in_msg_info);
/* Here I create another screen, load it and delete the old one */
lv_obj_t *scrAct = lv_scr_act();
lv_obj_t *newScr = lv_obj_create(NULL, NULL);
btn = lv_btn_create(newScr, NULL);
lv_disp_load_scr(newScr);
lv_obj_del(scrAct);
/* The rest of the code is the same as in the example */
I suspect that the delayed delete is the responsible of the fail, but I don’t know how to do it in another way, because other parts of the code have to have the possibility to change the current screen at any time.
Alex
