I tried to do this several ways but none worked.
This, for example:
const uint8_t my_1bit_img_data[] = {
0b11111111,
0b10000001,
0b10000001,
0b10000001,
0b10000001,
0b10000001,
0b10000001,
0b11111111
const lv_image_dsc_t my_1bit_img = {
.header = {
.magic = LV_IMAGE_HEADER_MAGIC,
.cf = LV_COLOR_FORMAT_I1, // 1-bit indexed
.w = 8,
.h = 8,
.data_size = sizeof(my_1bit_img_data),
.data = my_1bit_img_data,
void show_hollow_square()
lv_obj_t * img = lv_image_create(lv_screen_active());
lv_image_set_src(img, &my_1bit_img);
lv_obj_center(img);
lv_obj_set_style_image_recolor(img, lv_color_hex(0xFF0000), LV_PART_MAIN);
lv_obj_set_style_image_recolor_opa(img, LV_OPA_COVER, LV_PART_MAIN);
Showed a square but with random pixels, not the image defined in my_1bit_img_data.
And so, without any more options, I did it this way:
#define O 0xFF
#define X 0x00
const uint8_t my_image_map[] = {
// Color format (in binary, MSB..LSB): BBBBBGGGGGGRRRRR. 0x00,0xF1=Full red. 0x07,0xE0=Full green. 0xF8,0x00=Full blue.
0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00, 0x00,0x00,
// Alpha: 0xFF=100% visible. 0x00=Invisible.
O,O,O,O,O,O,O,O,O,O,O,O,O,O,O,O,O,O,
O,O,X,X,X,X,X,X,X,X,X,X,X,X,X,X,O,O,
const lv_image_dsc_t my_image = {
.header = {
.cf = LV_COLOR_FORMAT_NATIVE_WITH_ALPHA,
.w = 18,
.h = 18,
.data_size = sizeof(my_image_map),
.data = my_image_map
lv_image_set_src(img, &my_image);
lv_obj_center(img);
And it worked.
But its a big waste of memory compared with a binary map.
