I found a strange thing. After I modified some ui code in excuting well project. It excuted abnormal that powerup loading ui is quick and normal,but when I used some input device key to change ,it likes key changing is not accepted that keyinput changing is normal in simulation but ui has no changing . When I change a variable to const. It became normal. I have no idea about this .
STM32H7B0 within L1 cache.
V8.3
Find why and what make it slow
I tried change the u16* bltime to __IO(volatile) u16* bltime.
And finally used the const (10) instead of the *bltime.
u8 PowerSave_LcdBL_Manage(__IO u16 *bltime,u32 powertime,u16 input)
static u32 cnt_key_invalid = 0;
__IO static u16 cnt_lcdbl_down = 0,cnt_powerdown = 0;
if((Lock_Move == 0))
if((input == 0)&&(AxisCmdBit == 0))
if(cnt_lcdbl_down < 10)//*bltime)
cnt_lcdbl_down++;
if(*bltime)
Set_Lcd_Brightness(0);
Lock_Move = 1;
cnt_lcdbl_down = 0;
if((Lock_Move == 1) )
Dis_Key_2_Lvgl = 1;
if(input != 0)
Set_Lcd_Brightness(Lcd_BL_Level);
cnt_lcdbl_down = 0;
Lock_Move = 2;
if(cnt_powerdown < powertime)
cnt_powerdown++;
#if !SELF_AXIS_TEST
HAL_GPIO_WritePin(Battery_Hold_GPIO_Port,Battery_Hold_Pin,GPIO_PIN_RESET);
#else
dis_key_op = 1;
cnt_powerdown = 0;
if((Lock_Move == 2) &&( input == 0))
Lock_Move = 3;
if((Lock_Move == 3))
if(cnt_key_invalid < 10)
cnt_key_invalid++;
Dis_Key_2_Lvgl = 0;
Lock_Move = 0;
dis_key_op = 0;
if(Lock_Move == 3)
input = 0;
return Lock_Move;
